    Missing system logos and achievements without description
    missing logos achievements description
    2060
    • estani20
      estani20 last edited by
      Hi! Since the last update i get (about 10 days ago), my Recalbox missed some system logos in ES (like SNES and megadrive)
      Also, if I want to see a retroachievements' description pressing select on it, reteoarch doesn't show anything. When I try to go back with B button (or circle on Playstation pad), it shows an empty file Explorer. I don't know why my recalbox started working weird since that update, please help (and sorry for my bad English)
      Zing Substring 2 Replies Last reply Reply Quote 0
        Zing Global moderator Translator @estani20 last edited by
        @estani20 In which architecture are you having trouble? RPi3 / 2/1, PC 32/64?
        Are you using the default theme? Have you tried changing the theme, or even edit theme settings?
        estani20 1 Reply Last reply Reply Quote 0
        • estani20
          estani20 @Zing last edited by
          @zing sorry, i'm using a rpi3b. Everytime i get an update, it switches to the default theme (the new one). I tried to switch to the old theme, but system logos still missing
            @estani20 Try downloading an updated theme, and maybe even edit theme settings, that might solve.
            If it does not work, it is recommended that you try to do a clean install of the latest version, as some errors may occur during upgrades due to system customizations.
              Substring @estani20 last edited by
              @estani20 said in Missing system logos and achievements without description:
              A version number is always better than "last update"
              If some parts are missing, it would look le ke the upgrade partially failed. This can be checked in a support archive eventually
              B in SNES layout is not tye button to go back in RA, it's the one that validates, like in ES. So i'm not sure what you've reached then
              • estani20
                estani20 @Substring last edited by
                @substring Sorry, i'm using an xbox controller. It's the A button in SNES layout
