    Solved Problems files remap * .rmp
    remap rmp
    • Digola
      Digola last edited by
      Hey, guys.
      After the 18.06.26 update the * .rmp (remap) of the folder
      \ recalbox \ share \ system \ .config \ retroarch \ config \ remaps \ FB Alpha
      they are no longer working, can anyone help me?
      • Marcos Breviglieri
        Marcos Breviglieri last edited by
        @substring Same problem here. Although the file is loaded when fba starts, button mapping does not work. Can you help with some solution?
          save file on your computer
          delete rpm file and re create rpm file
          Digola 1 Reply Last reply Reply Quote 0
          • Digola
            Digola @acris last edited by Digola
            @acris SOLVED
            The remap file has been modified.
            In=
            input_player1_b = "1"
            input_player1_y = "0"
            input_player1_a = "9"
            input_player1_x = "8"
            input_libretro_device_p1 = "0"
            input_player1_analog_dpad_mode = "1"
            input_player2_b = "1"
            input_player2_y = "0"
            input_player2_a = "9"
            input_player2_x = "8"
            input_libretro_device_p2 = "1"
            input_player2_analog_dpad_mode = "0"
            input_libretro_device_p3 = "1"
            input_player3_analog_dpad_mode = "0"
            input_libretro_device_p4 = "1"
            input_player4_analog_dpad_mode = "0"
            input_libretro_device_p5 = "1"
            input_player5_analog_dpad_mode = "0"
            For=
            input_player1_btn_b = "1"
            input_player1_btn_y = "0"
            input_player1_btn_a = "9"
            input_player1_btn_x = "8"
            input_libretro_device_p1 = "1"
