    Recalbox 18.06.27 pc-laptop problemas con señal HDMI
    recalbox 18.06.27 pc-laptop problemas con
    • josklown
      josklown last edited by
      Que tal amigos, tengo problemas con el puerto hdmi porque no me da señal, e visto en barios esta misma pregunta pero no logro hacer que funcione, me podrían ayudar?
      Les dejo mi recalbox.conf.... gracias!
      (pongo de tal manera mi archivo porque no me deja subir el archivo, dice que no tengo suficientes privilegios para hacer esa acción)
      System Variable
      You can configure your recalbox from here
      To set a variable, remove the first ; on the line
      ------------ A - System Options -----------
      Recalbox Manager (http manager)
      system.manager.enabled=0
      1 or 2, depending on the manager version you wish
      system.manager.version=2
      Recalbox security
      enforce security
      samba password required
      disable virtual gamepads
      system.security.enabled=0
      Recalbox API (REST)
      system.api.enabled=0
      EmulationStation
      menu style
      default -> default all options menu
      none -> no menu except the game search menu
      bartop -> less menu, only needed for bartops
      emulationstation.menu=default
      Select a system to show on boot (use rom directory name) (string)
      emulationstation.selectedsystem=c64
      Show the gamelist of the first or selected system on boot (0,1)
      emulationstation.bootongamelist=0
      Disable system view ES will boot and show ONLY the first or selected system (0,1)
      emulationstation.hidesystemview=0
      Pa**e Gamelists only. Show only games listed in gamelist.xml files (0,1)
      emulationstation.gamelistonly=1
      Force basicgameList view to be displayed, even if your game systems are scraped (0,1)
      emulationstation.forcebasicgamelistview=0
      Emulator special keys
      default -> default all special keys
      nomenu -> cannot popup the emulator menu
      none -> no special keys in emulators
      Show or hide kodi in emulationstation (0,1)
      kodi.enabled=0
      Start kodi at launch (0,1)
      kodi.atstartup=0
      set x button shortcut (0,1)
      kodi.xbutton=0
      Kodi can wait for a network component before starting
      waithost is the ip or hostname that must answer to a ping to validate the availability
      waittime is the maximum time waited when kodi boots
      if waitmode is required, kodi will not start if the component is not available
      if waitmode is wish, kodi will start if the component is not available
      if waitmode is not set or has another value, kodi will start immediately
      ;kodi.network.waittime=10
      ------------ B - Network ------------
      Set system hostname
      system.hostname=RECALjOs
      Activate wifi (0,1)
      wifi.enabled=1
      Wifi SSID (string)
      wifi.ssid=Juan&Jorge
      Wifi KEY (string)
      after rebooting the recalbox, the "new key" is replace by a hidden value "enc:xxxxx"
      you can edit the "enc:xxxxx" value to replace by a clear value, it will be updated again at the following reboot
      Escape your special chars (# ; $) with a backslash : $ => $
      wifi.key=enc:U2FsdGVkX1+Q0FtvFYq7KnjQeQauqcsPaIcRQ4xIbS8=Grettel24
      secondary wifi (not configurable via the user interface)
      ;wifi2.ssid=new ssid
      ;wifi2.key=new key
      third wifi (not configurable via the user interface)
      ;wifi3.ssid=new ssid
      ;wifi3.key=new key
      Samba share
      system.samba.enabled=1
      Virtual Gamepads
      SSH
      system.ssh.enabled=1
      ------------ C - Audio ------------
      Set the audio device (auto, hdmi, jack)
      #hdmi_group=1
      #hdmi_mode=1
      audio.device=auto
      Set system volume (0..100)
      audio.volume=87
      Enable or disable system sounds in ES (0,1)
      audio.bgmusic=1
      -------------- D - Controllers -----------------
      Enable support for standard bluetooth controllers
      Please enable only one of these
      -------------- D1 - PS3 Controllers ------------
      controllers.ps3.enabled=1
      Choose a driver between bluez, official and shanwan
      bluez -> bluez 5 + kernel drivers, support official and shanwan sisaxis
      official -> sixad drivers, support official and gasia sisaxis
      shanwan -> shanwan drivers, support official and shanwan sisaxis
      controllers.ps3.driver=bluez
      ------------ D2 - GPIO Controllers ------------
      GPIO Controllers
      enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
      controllers.gpio.enabled=0
      mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
      controllers.gpio.args=map=1,2
      DB9 Controllers
      Enable DB9 drivers for atari, megadrive, amiga controllers (0,1)
      controllers.db9.enabled=0
      db9 arguments
      controllers.db9.args=map=1
      Gamecon controllers
      Enable gamecon controllers, for nes, snes psx (0,1)
      controllers.gamecon.enabled=0
      gamecon_args
      XGaming's XArcade Tankstik and other compatible devices
      controllers.xarcade.enabled=1
      ------------ F - Language and keyboard ------------
      Set the language of the system (fr_FR,en_US,en_GB,de_DE,pt_BR,es_ES,it_IT,eu_ES,tr_TR,zh_CN)
      system.language=es_ES
      set the keyboard layout (fr,en,de,us,es)
      system.kblayout=us
      Set you local time
      Select your timezone from : ls /usr/share/zoneinfo/ (string)
      system.timezone=Mexico/General
      ------------ G - UPDATES ------------
      Automatically check for updates at start (0,1)
      updates.enabled=1
      Update type : default to stable
      updates.type=stable
      ------------ H - HERE IT IS - GLOBAL EMULATOR CONFIGURATION ------------
      The global value will be used for all emulators, except if the value
      is redefined in the emulator
      Set game resolution for emulators
      Please don't modify this setting
      This arch does not support the video mode switch
      (string)
      global.videomode=CEA 1 HDMI
      #hdmi_drive=2
      Shader set
      Automatically select shaders for all systems
      ## (none, retro, scanlines)
      global.shaderset=none
      Once enabled, your screen will be cropped, and you will have a pixel perfect image (0,1)
      global.integerscale=1
      Set gpslp shader for all emulators (prefer shadersets above). Absolute path (string)
      global.shaders=
      Set ratio for all emulators (auto,4/3,16/9,16/10,custom)
      global.ratio=auto
      Set smooth for all emulators (0,1)
      global.smooth=1
      Set rewind for all emulators (0,1)
      global.rewind=1
      Set autosave/load savestate for all emulators (0,1)
      global.autosave=1
      Enable retroarchievements (0,1)
      Set your www.retroachievements.org username/password
      global.retroachievements=1
      global.retroachievements.hardcore=1
      Set retroarch input driver (auto, udev, sdl2)
      If you don't have issues with your controllers, let auto
      global.inputdriver=auto
      If you do not want recalboxOS to generate the configuration for all emulators (string)
      ------------ I - EMULATORS CHOICES -----------
      You can override the global configuration here
      Here is the snes example
      snes.core=snes9x_next
      ;snes.ratio=16/9
      ;snes.smooth=1
      ;snes.rewind=1
      ;snes.autosave=0
      ;snes.emulator=libretro
      ;snes.integerscale=0
      If you do not want recalboxOS to generate the configuration for the emulator :
      Default cores for x86
      gba.core=mgba
      mame.core=mame078
      nes.core=fceunext
      n64.core=glide64mk2
      psx.core=mednafen_psx_hw
      NeoGeo emulator
      You can use pifba or a libretro core (fba2x,libretro)
      neogeo.emulator=libretro
      If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
      neogeo.core=fba
      wiimotes
      real wiimotes must not be paired with recalbox system so that they can work with the wii emulator
      ## set emulatedwiimotes to 1 to emulate wiimotes with standard pads
      wii.emulatedwiimotes=0
      Configurations generated by Recalbox
      system.kblayout=us
      wii.autosave=1
      wii.ratio=auto
      JDPT93 Zing 2 Replies Last reply Reply Quote 0
      • JDPT93
        JDPT93 @josklown last edited by
        @josklown tengo el mismo problema 😞
          Zing Global moderator Translator @josklown last edited by
          @josklown @JDPT93 No uso la versión de PC, así que no puedo ayudar mucho, pero lea este tema (en inglés), que habla sobre un comando llamado xrandr, que es lo que debe funcionar para usted:
          https://forum.recalbox.com/topic/14398/menu-and-kodi-is-not-full-screen-on-old-netbook/5
