    Solved MSX system does not work after upgrade to version 18.06.27
    Emulator Arcade/PC/Console
    msx does upgrade version 18.06.27
    9
    26
    10726
    • leaf
      leaf @paradadf last edited by
      @paradadf Thanks for the reply! I'm going to do the installation cleanly, and then check if the emulator appears fmsx. much thank you for the help!: D
      • leaf
        leaf last edited by leaf
        Hello everyone! I finally figured out why Fmsx did not show up. I did a clean install and the problem really was in that. I then compared the two installations, and realized that in my previous installation there was the file called "es_systems.cfg" which I think was broken. After the clean installation everything worked out. Fmsx now appears to change. 😄
        Thanks to everyone who posted on the topic, and for all the help! Thank you! Sorry for my English.
        • Exeter
          Exeter last edited by
          This post is deleted!
            If you want you can test a branch test taht should fix this issue.
            In your recalbox.conf file, edit the G - UPDATES section :
            updates.type=stable -> updates.type=https://review-505-msx-on-yfowtk-archive-review-prod.recalbox.com
            Do the upgrade asked by the system, then test Bluemsx core on msx and colecovision.
            Jarlaxe 1 Reply Last reply Reply Quote 0
            • Jarlaxe
              Jarlaxe @rockaddicted last edited by
              @rockaddicted said in MSX system does not work after upgrade to version 18.06.27:
              Hi!
              This custom update don't work.
              Error when trying to download. 😞
                Not availible because the branch merged.
                you need to wait next update
                100.2k
