    2 player keyboard error
    GamePad/GPIO/USB encoder
    player keyboard
    1681
    • Sziszee
      Sziszee last edited by
      Hi i create a 2 player controller from an old usb keyboard and its just partly working. I added it to xarcade2jstick and its work just the keymap is not the same. How can i remap the xarcade keymap? I dont want to resolder and rewiring the whole keymatrix. I hope to you understand my problem sorry for my bad english i dont speak it very well. Thanks.
        Substring @Sziszee last edited by
        @sziszee you can't remap xarcade2jstick, Which is based on the classic mame configuration
        Sziszee 1 Reply Last reply Reply Quote 0
        • Sziszee
          Sziszee @Substring last edited by
          @substring Thanks for the fast reply. So no solution to my problem? There is no way to play 2 person in 1 keyboard?
          • Quemandoacromo
            Quemandoacromo last edited by
            The solution is that you have to configure different keys for the 2nd player and mapping this in retroarch.cfg
            • Sziszee
              It's partly working but when i quit retroarch and load a game again the recalbox autoconfig always overwrite my cfg file. Anyway to disable autoconf or what should i do to save my retroarchcustom.cfg settings? Thanks.
                voljega Banned @Sziszee last edited by
                @sziszee it's recalbox, not retropie, you must configure your joysticks in EmulationStation, not retroarch
                101.4k
