    NETPLAY : SELECT not working anymore - feedback
    netplay select anymore feedback
    8
    31
    12268
    • tonificante
      tonificante @Substring last edited by
      @substring Sorry, I forgot to set is as executable... It seems to work fine now! Tested local play without netplay and local netplay. I couldn't test it joining to another netplay because at the moment I cannot find a properly game but I think it will work
        Substring @tonificante last edited by
        @tonificante if it works when you host, it will work as a client too
        • rizzie
          rizzie last edited by
          Hello~ Substring.
          I have long since used the select button with select and hotkey functions.
          I have not had any problems so far.
          However, after this update, The 1P and 2P coin function does not work in 2 ~ 4 games like Cadillac, Dungeon & Dragon etc (FBA_Libretro game) at local play instead of net play mode.
            Substring @rizzie last edited by
            @rizzie read the whole topic you'll know what to expect
            rizzie 1 Reply Last reply Reply Quote 0
            • rizzie
              rizzie @Substring last edited by
              @substring Yes! Got it! It's working now~ Thanks very much~~
              • cleanderson
                cleanderson @Substring last edited by
                This post is deleted!
                • cleanderson
                  @substring said in NETPLAY : SELECT not working anymore - feedback:
                  @marcos-breviglieri Download a new retroarch binary from https://we.tl/vMgfWfUjFk
                  Replace the original one (make a backup) in /usr/bin and don't forget to chmod +x /usr/bin/retroarch
                  Hello friend, I have no knowledge in linux,
                  But could you help me solve this problem?
                    Substring @cleanderson last edited by
                    @cleanderson if you have no knowledge, you'd vetter wait for the upgrade
                    • jorgemagana
                      jorgemagana last edited by
                      Was this solved in the July update? Thanks.
                      • Gaetan
                        Gaetan Theme moderator @jorgemagana last edited by
                        @jorgemagana Yes it was
                        jorgemagana 1 Reply Last reply Reply Quote 0
                        • jorgemagana
                          jorgemagana @Gaetan last edited by
                          @gaetan Thanks, I will update today my recalbox!
                          100.8k
