    System Sound staying at 0
    sound staying
    1948
    • dvickery1
      dvickery1 last edited by
      Hey Everyone,
      I have recallbox on a PC and I performed the latest update this morning. Came back to no sound and the System sound staying at 0% even if I attempt to change it. Anyone else with this same issue who might have a possible fix?
      Thanks
      • gnubit
        gnubit last edited by
        @dvickery1
        have you tried this ?
        https://forum.recalbox.com/topic/13906/update-18-04-2018-x86-x86_64-sound-problem
        dvickery1 1 Reply Last reply Reply Quote 0
        • dvickery1
          dvickery1 @gnubit last edited by
          @gnubit
          Thank you for your reply. I did but, unfortunately, I did not get the same output as what is shown on the screenshots. I used Putty to SSH to my recalbox PC and was successfully able to log in. When I did and I followed the directions, I did not see a screen with the different bars that you could un-mute, like you see on the 2 screenshots of the post.
            Substring @dvickery1 last edited by
            @dvickery1 press F6 to reach other sound cards
            • dvickery1
              dvickery1 @Substring last edited by
              @substring
              I use F6 and I get the following:
              When I select the card, nothing really changes.
                @dvickery1 then in ES, select that sound card instead of auto, who knows
                • dvickery1
                  @substring
                  Ding Ding Ding! Thank you sir, I appreciate it. Once I selected the HDMI, that brought my sound back. I appreciate it sir. Have a great day!
