    Can't add roms Disk usage N/A ?! 128GB card
    cant roms usage 128gb card
    4822
    • RickZ
      RickZ last edited by
      Hi everyone i am new to the raspberry pi/ recalbox thing.
      I followed the instruction and downloaded the image (recalbox.img.xz) on recalbox.com and flash the image with Etcher as instructed.
      The problem is once flashed i put it in my raspberry pi and it says disk usage N/A and i cannot add any roms through network it always says the space is full even if i know there is more than 100gb free.
      I tried twice, once in FAT32 and one in exFAT but still the same problem what's going wrong here??
      My setup
      Official Samsung EVO plus 128GB SDCard
      Raspberry PI 3 B
      Thanks in advance for your help
      Substring MilesCW 3 Replies Last reply Reply Quote 0
        Substring @RickZ last edited by
        @rickz samsung evo work rather bad for recalbox, better go with a sandisk sd.
        And some better advice : use a small sd, but have your roms on a usb stick
        • MilesCW
          MilesCW @RickZ last edited by MilesCW
          @rickz The Samsung EVO works well. In fact, I'm using the 256GB version and had the very same issue as you have.
          Install one of the older recalbox-versions, like the 4.0.1 or 4.0.2. Shouldn't they work, then go with even an older one. Unfortunately I don't remember which version I used for it but I think it was an 3.x-version.
          @Substring The issue is that the newer ones actually do not install but just boot the OS on Samsung-cards. I had no problems installing it with an older version.
          Substring 1 Reply Last reply Reply Quote -2
            Substring @MilesCW last edited by
            @milescw how is that a solution to suggest installing a 2 years old version of recalbox that can't update ?
            MilesCW 1 Reply Last reply Reply Quote 0
            • MilesCW
              MilesCW @Substring last edited by MilesCW
              @substring It's at least a working solution and I'm at the current OS-version after I updated it from the recalbox-menu itself.
                @rickz please make a support archive, thanks
