    Solved Netplay troubleshooting
    Emulator Arcade/PC/Console
    netplay troubleshooting
    • ivwshane
      ivwshane last edited by
      I'm testing the netplay functionality and then I host a game (launch with X) it loads the rom, a message appears on the bottom of the screen that I've joined a player 1, the title spears, and then it kicks me out to the game list menu. I can play the game locally just fine.
      What issues do I need to look for? If it matters I'm trying super Mario kart for snes and I've tried super street fighter ii as well.
      I'm on a 100mb wired connection.
        @ivwshane
        use catsfc or snes9x
        no snes9x_2010 it not working
        • joinski
          joinski last edited by joinski
          I'm also testing the netplay functionality and i am not able to get it running. I have 2 PCs with Recalbox 18.06.27 (x86_64), both with identical settings and roms and connected to the internet.
          When i start the host on the first PC and try to join from the second PC it always says:
          "Failed to initialize netplay."
          I tried with catsfc and snes9x (no snes9x_2010)
          I scraped and hashed all my roms
          And in Netplay Lobby i get the green Ok result (Rom and core match).
          But still it does not work ("Failed to initialize netplay" on the PC that tries to join the host).
          ++UPDATE++
          Problem solved! It was the UPnP-Settings in my Router. I activated UPnP and now it works 🙂
