    Recalbox 18.06.27 is out!
    Announcements
    recalbox 18.06.27 out
    34
    103
    100109
      Hey merry retrogamers !
      Time for a new upgrade ! And what an upgrade !!!
      Head over to the blog to know all about it !
      voljega 1 Reply Last reply Reply Quote 7
        voljega Banned @Substring last edited by
        @substring pfiou actually yes awesome and gigantic update !!
        just for that one, I'm more than happy 😄
        ES: Stay is selected sub-folder when changing sort type / order in gamelist: en triant une gamelist, on se retrouvait à la racine du système, mais c’est du passé à présent
        congrats for finding the bug !
        • Gaetan
          Gaetan Theme moderator last edited by
          Changelog is awesome, the biggest since the 4.1!
          Netplay is one of the feature that player couldn't dream of. Now I can fight some friends from the other side of the world 😄
          • kelv
            kelv last edited by
            Upgrading 50% still progressing!!
            Raspberry Pi model: RPi 3b+
            Recalbox build : 7.0.1 DragonBlaze
            Hardware: MicroSD UHS 128 GB up to 80 MB, Class 10 and 2.5 A Power Supply.
            Overclocked: 1485 MHZ
            Controller(s): Wired Xbox 360 PAD (working perfectly on any other game/emulator).
            • Sebastien Brossard
              Sebastien Brossard last edited by
              Good Job,
              but afer upgraded I can't load my game save , does the location change for save folder ? (/share/save/fba_libtrero/) ?
                Substring @Sebastien Brossard last edited by
                @sebastien-brossard nope it didn't change, but the fba version changed
                voljega Sebastien Brossard 2 Replies Last reply Reply Quote 0
                • kelv
                  kelv last edited by kelv
                  @Substring I'm having issues with the overclock settings
                  Overclocked as the following parameter doesn't launch emulationstation (all my previous versions of recalbox worked fine with these settings)
                  Overclock
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=512
                  avoid_safe_mode=1
                  kernel=zImage
                  NOOBS Auto-generated Settings:
                  hdmi_force_hotplug=1
                  arm_freq=1345
                  core_freq=500
                  sdram_freq=575
                  force_turbo=0
                  over_voltage=4
                  over_voltage_sdram_p=6
                  over_voltage_sdram_i=4
                  over_voltage_sdram_c=4
                  gpu_freq=500
                  sdram_schmoo=0x02000020
                  v3d_freq=500
                  h264_freq=333
                  gpu_mem=256
                  Overclocked as follows, works fine but after playing dreamcast for 5 minutes and coming back to emulationstation crashes
                  It also crash after getting into netplay and doing hash configuration.
                  Overclock
                  gpu_mem_256=128
                  gpu_mem_512=256
                  gpu_mem_1024=512
                  avoid_safe_mode=1
                  kernel=zImage
                  arm_freq=1335
                  core_freq=500
                  sdram_freq=575
                  force_turbo=0
                  over_voltage=4
                  gpu_freq=500
                  v3d_freq=500
                  h264_freq=333
                  gpu_mem=256
                  I'm wondering if emulationstation update is too heavy... 😞
                  Substring 1 Reply Last reply Reply Quote -1
                    Substring @kelv last edited by
                    @kelv I never ever overclock my pi
                    • reda_zin
                      reda_zin last edited by
                      Il y a une nouvelle version mame ?
                      Je prépare déjà les roms fba en 0.2.97.43 mais pour mame faut prévoir un changement ?
                      Merci.
                      • Gaetan
                        Gaetan Theme moderator @reda_zin last edited by
                        @reda_zin la version mame est la même, c'est le set fba qu'il faut mettre à jour
                        reda_zin 1 Reply Last reply Reply Quote 0
                        • reda_zin
                          reda_zin @Gaetan last edited by
                          @gaetan merci ☺️
                          • Murdock
                            Murdock last edited by
                            J en profite pendant que vous parlez des romsets, le gamelist a t il besoin d être mis à jour lui aussi ? J ai lu qq part que ce n est pas obligatoire pour l arcade mais vu qu on se base sur le hash...😅
                            RPI 3, chargeur 3A, SD sandisk 16go, Disque dur externe Toshiba 1To, nes30Pro
                            reda_zin Substring 2 Replies Last reply Reply Quote 0
                            • reda_zin
                              reda_zin @Murdock last edited by
                              @murdock il ne me semble pas que le gamelist doit être changé, je n'ai jamais dû y toucher suite à une maj.
                              • kelv
                                @Substring I have blank screen with music (so it's loading the rom) in this update at N64 using muplen64plus with Rice with any game. I change the following video setting and no success
                                N64 emulator is configured to display a screen with a 640x480 resolution (native n64 resolution)
                                So you must use one of these video modes (DMT 4 HDMI,CEA 1 HDMI).
                                If your screen is not compatible with one of these video modes, please check the recalbox's wiki.
                                n64.videomode=DMT 4 HDMI
                                I also tested with auto DMT 4 HDMI with no success. As release notes state that there are changes.
                                With other cores work fine except RICE
                                I created two support files
                                https://file.ac/7Dfj66OHvHs/ during gameplay
                                https://file.ac/dJaeuB5rrBk/ after gameplay
                                THX
                                  @substring said in Recalbox 18.06.27 is out!:
                                  in last version 18-06-27 ? nothing in changelog ?
                                    Substring @voljega last edited by
                                    @voljega b*mped to .43 in 18-06-27 yes. Would i have forgotten to write it explicitely in the changelog ? It says at least "all libretro cores b*mped"
                                    voljega Lasly 2 Replies Last reply Reply Quote 0
                                      @kelv which screen are you using ?
                                      kelv 1 Reply Last reply Reply Quote 0
                                        Yes and also afaics there is not dat in fba_libretro folder for 43 version ?
                                          @voljega there is
                                          • Flavest
                                            Flavest last edited by
                                            Bonsoir. C’est mon premier message ici. Jusque là je me suis plutôt débrouillé tout seul mais là j’ai un souci avec cette dernière maj. Celle-ci reste bloquée à 63% et cela par deux fois. Une idée d’où cela peut venir ? Merci d’avance.
