    N64 emulator/core
    in64 emulatorcore
    • looneymetal
      looneymetal last edited by looneymetal
      Hi Guys,
      Just playing around with the build and have selected the best Core's for each individual rom for the N64 to ensure the best performance. I was just wondering where this information saves to? is there a specific file that i can back up so that i can transfer from my 32gb build to my 128gb build? without having to manually select the cores again for each game?
      Many thanks,
      Sven
        paradadf Staff @looneymetal last edited by
        @looneymetal yes... look in the respective gamelist.xml file.
        • looneymetal
          I did check here, tested with a single game and didn't see any core in the info, just rechecked after reading your message and looks like i made the school boy error of checking the US (u) rom instead of the Europe (e) that i edited. thank you Paradadf
            @looneymetal just be sure to reboot your recalbox after any change you made so that it gets stored.
