    Reduce resolution on PC
    reduce
    4341
    • Beldar
      Beldar last edited by
      Hello,
      I am running the latest stable release of recalbox on a 7th generation Intel NUC x86 64bit. Recalbox is installed directly on the hard drive.
      My issue is that I am using a 4k TV via HDMI and that is too much for my system to handle. I was going to edit the conf file and add hdmi_group=1 and hdmi_mode=16 to get a permanent 1080p resolution.
      However, I cannot changed the conf file because it says the file system is read only. I have tried manually using nano over ssh on my Windows computer, but still no luck.
      How can I scale back the resolution?
        Substring @Beldar last edited by
        @beldar the edit you're trying to do is only for pi. We haven't yet set up a way to cha ge resolution on PC unless you dig this manually
        Beldar 1 Reply Last reply Reply Quote 0
        • Beldar
          Beldar @Substring last edited by
          @substring
          Thank you for the quick response. So, there is currently no way for me to change the resolution or were you saying there is a way to do it manually? I'm not a linux expert, but I'm pretty good at following instructions if there is a way. Thanks again.
          Substring gnubit 2 Replies Last reply Reply Quote 0
            @beldar there is a way, of course. Just haven't searched. It's most probably toying around with xrandr and the xinitrc file. Rockaddicted may have pisted some infos regarding that. I can't be of much more help right now as i'm at work
            • gnubit
              gnubit @Beldar last edited by acris
              @beldar
              This works for me as @SUBSTRING suggested editing xinitrc
              Sources: https://wiki.archlinux.org/index.php/Xrandr
              ssh into box, then do the following:
              cp /etc/X11/xinit/xinitrc ~/.xinitrc
              It will copy ~/.xinitrc to /recalbox/share/system (/recalbox/share/system/.xinitrc)
              From there you can edit it with vi/nano from ssh, or use winscp/filezilla to edit /recalbox/share/system/.xinitrc
              add this to the file: (1080p as an example)
              xrandr -s 1920x1080
              Note if you intend to use nano you may need to export the environment variable first with:
              export TERM=xterm
              nano /recalbox/share/system/.xinitrc
              I have linked my working .xinitrc to force 720p:
              .xinitrc recalbox
              Beldar Substring 3 Replies Last reply Reply Quote 2
              • Beldar
                Beldar @gnubit last edited by
                @gnubit Thanks! I work all day today but I will follow your instructions tomorrow and see if I can get it working. I appreciate your time.
                  Substring @gnubit last edited by
                  @gnubit i'd really love if you make a wiki page about this (if it's not existing yet, i losy the count ...)
                  • Beldar
                    @gnubit I ended up with a few minutes before work. Your instructions had my problem fixed within five minutes. Cheers!
                    gnubit 1 Reply Last reply Reply Quote 0
                    • gnubit
                      gnubit @Beldar last edited by gnubit
                      @beldar said in Reduce resolution on PC:
                      Your`e most welcome, glad it worked for you 🙂
                      @substring said in Reduce resolution on PC:
                      I would like to contribute (give back) since I enjoy recalbox so much, but I don`t know where to start. I do not think this topic exists in the wiki and think it should as it would help others. Could you point me in the right direction ? I am also quite happy for someone else to add it if they wish.
                        @gnubit please add en entry in the video section of https://github.com/recalbox/recalbox-os/wiki/Mini-How-To-(EN)
                        Name it like "x86: change display resolution". You need angithub accoubt to edit. The wiki uses the markdown syntax (as well as the forum), you can use the toolbar or read some tutorials on the net to get the syntax. I'll help if you need
                        • gnubit
                          @substring
                          Thanks, done.
                          Change display resolution on x86 x86_64
                          DieHardMan 1 Reply Last reply Reply Quote 2
                          • DieHardMan
                            DieHardMan @gnubit last edited by
                            @gnubit Thanks for the tutorial, but on my NUC7 i had to insert a "sleep 1" before the "xrandr -s 1920x1080" line to make it working.
                            Without "sleep" it fully started (you could hear the music and ssh access was possible) and the tv displayed the correct resolution but the screen was black.
