    Solved recalbox resolution problem
    recalbox
    • manesis78
      manesis78 last edited by manesis78
      hi i have a problem.i have rasberry pi3 and an old lcd monitor 4:3 and it has 2 inputs vga and dvi.i have connect with hdmi adaptor to vga and i see the menu of recalbox.when i start the game i have no screen on my monitor it says the resolution is not supported.do you have an idea what is wrong?if i find the cable is better to connect to dvi?thank you sorry for my english 🙂
        Hello
        https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-DVI-screen-(EN)
        https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
        • manesis78
          hi thank you for your answer with this link https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
          i have no success i have made so many tests.do you think its better to connect with dvi or my monitor is bad i have a hyundai u90d
          • manesis78
            so many test i have with the config.txt i will try with the recalbox.conf and i will tell you thank a lot
            • manesis78
              i edit the recalbox.conf and all ok thank you very much
