    Solved Bluetooth controller won't automatically reconnect after restarting the Pi
    GamePad/GPIO/USB encoder
    8bitdo bluetooth reconnect restart
    • r4ndom4is
      r4ndom4is last edited by
      Is there a way to make the 8Bitdo SF30 bluetooth controllers to automatically reconnect after a restart?
      Currently I have to turn them off and back on again to reconnect.
      Apologies if this has already been discussed before but I could not find a similar topic/answer.
      Recalbox 18.04.20
      latest SF30_Firmware_V4.10
        Substring @r4ndom4is last edited by
        @r4ndom4is it's supposed ti reconnect uf you start your controller after ES has started launching
        r4ndom4is 1 Reply Last reply Reply Quote 0
        • r4ndom4is
          r4ndom4is @Substring last edited by
          So here's my scenario @substring
          1. I've got the controllers nicely connected
          2. I then restart Recalbox from the ES menu
          3. Controllers obviously lose connection while Recalbox restarts and boots up to ES
          4. Controllers stay blinking, won't automatically reconnect
          5. I need to turn the controllers off and back on for them to connect again
          Is this how bluetooth peripherals generally work with Recalbox or could I modify something somewhere to get the controllers to automatically reconnect? Would the recalbox-support.sh output help to troubleshoot?
            @r4ndom4is that.s the way they work, that's the way BT stabdards define connectiins between client (your pad) and host (the pi)
            • r4ndom4is
              @substring thank you again for the quick reply.
              RESOLVED
