    PIGRRL 2.0 CUSTOM GAMEPAD
    GamePad/GPIO/USB encoder
    pigrrl 2.0 gamepad
    • bigbear
      bigbear last edited by
      I'm the process of putting together an adaFruit PiGRRL 2.0 project - essentially a portable arcade - https://learn.adafruit.com/pigrrl-2/overview
      The project is developed around the use of RetroPie but I would prefer to use Recalbox.
      The controller is a custom adaFruit Gamepad which requires an application called retrogame to convert button presses to keyboard strokes.
      adaFruit Gamepad: https://learn.adafruit.com/pigrrl-2/gamepad
      adaFruit Retrograme: https://github.com/adafruit/Adafruit-Retrogame
      The github page for Retrogame has a section which talks specifically about RetroPie 2.0+ Compatibility:
      Note that by default retrogame won't work with SDL2 applications that depend on evdev for input events. Specifically this means applications like the latest version of RetroPie and EmulationStation won't be able to see key events generated by retrogame. However you can fix this issue by adding a small custom udev rule to make retrogame keyboard events visible to SDL2.
      Connect to your Raspberry Pi in a terminal/SSH session and execute the following command to create and edit the file /etc/udev/rules.d/10-retrogame.rules:
      How relevant is this in the context of Recalbox?
      I have tried installing the retrograme binary myself and am able to get it to work ok within EmulationStation but as soon as I launch a game button clicks don't register.
      Any suggestions on what I can try would be greatly appreciated.
      Cheers
      Gerard
        Hello @bigbear
        May be help
        https://github.com/recalbox/recalbox-os/wiki/Touches-du-clavier-via-GPIO-(FR)
        bigbear 1 Reply Last reply Reply Quote 0
          Substring @bigbear last edited by
          @bigbear hi
          What kind of inputs does it naturally generate ?
          • bigbear
            bigbear @acris last edited by
            Hi @acris
            I gave this a go with no luck. I'm also using an Adafruit 2,8" TFT which is using it's own GPIO pins and I suspect that mk_arcade might be trying to use the same pins.
            Do you know if it is possible to configure the pins that mk_arcade is using?
            Cheers
            Gerard
            101.4k
