    [Theme] Clean Retro
    Themes & Interface
    [theme] clean retro
    41
    81
    74567
    • sheyk90
      sheyk90 last edited by
      Fixed theme problems: https://mega.nz/#!zxhyhAKR!2b57oMBUKiCNGqrETFeXOIy_xYGxX0ir9xgDVkBwEaQ
      Backgrounds are 50% darkness now, you can read words better.
      • A Former User
        A Former User last edited by
        @sheyk90 said in [Theme] Clean Retro:
        Never update our theme. Please delete this file. The theme here is outdated as we can't write the team name in it. It's now on our Github. Do a Google search you guys should find it. The theme work 100% perfectly with our official version.
        AGAIN, never update someone else's work because after people will come on our Discord and tell us it's not working.
        Thanks for your comprehension!
        Bardamuz voljega nico-irano 3 Replies Last reply Reply Quote 1
        • Bardamuz
          Bardamuz @Guest last edited by digitaLumberjack
          @deletedaccount said in [Theme] Clean Retro:
          Can't find your Github and neither your Discord 😞
          Same player shoot again
            voljega Banned @Guest last edited by digitaLumberjack
            @deletedaccount yep it would be better if you put your github and discords in your signature
            • nico-irano
              nico-irano @Guest last edited by digitaLumberjack
              @deletedaccount
              Is it the EMULGA theme? If yes, it had same problem.
              Maybe conflict with newer Version of recalbox?
              • A Former User
                The theme works with the latest version of Recalbox 18.07.13
                Remains untested with the released betas.
                Can't add the links in my signature, it's been forbidden by the RB staff.
                I'm not the one making the rules, I'm the one following them.
                nico-irano 1 Reply Last reply Reply Quote 0
                • nico-irano
                  @deletedaccount
                  Ok, link?
                    paradadf Staff @nico-irano last edited by
                    @nico-irano no links because it is full of copyrighted content.
                    • nico-irano
                      ok, so what i wanna Know, is : the Theme linked in the first post has this problem. Anyone has tried the theme on github? Problem solved? I can't find the theme....i googled it but nothing.
                      sheyk90 1 Reply Last reply Reply Quote 0
                      • tarraske
                        tarraske Theme moderator last edited by
                        They could open an exception for at least the theme to be functional, because it is not due to the black screens when leaving the games, it's a shame as it is an incredible theme.
                        • sheyk90
                          sheyk90 @nico-irano last edited by
                          @nico-irano said in [Theme] Clean Retro:
                          Theme on github is emulga box and is similar with some new system added but it has the same problems. That is the reason because i've fixed the problems some days ago.
                          • tarraske
                            @sheyk90 Have black screen problems been solved too?
                            nwildner 1 Reply Last reply Reply Quote 0
                            • nico-irano
                              nico-irano @sheyk90 last edited by
                              @sheyk90 low quality background, but hope it works
                              • sheyk90
                                I konw it, but is the solution. Raspberry is not powerful...
                                • nwildner
                                  nwildner @tarraske last edited by
                                  @tarraske @nico-irano @sheyk90
                                  Found a good solution to all problems with this theme. Every time i tried to exit a game, a black screen happend(and ES got killed). If i set gpu_mem_1024=384 or lower, white artifacts started to happen instead of loading background/system title/ whatever images.
                                  If gpu_mem_1024=512 was set, EmulationStation would be killed by Linux Out of Memory management, since there was not RAM enough
                                  Solution to make this theme work:
                                  • Set gpu_mem_1024=448 on /boot/config.txt (64+128+256)
                                  • Set overclocking to 1300 inside EmulationStation (i have a MEGApi case and this, a working fan)
                                  • Reclaim some extra memory by disabling web manager, recalbox api and Samba share. DON'T do this if you are using a system where you are putting roms or tinkering constantly. Edit /recalbox/share/system/recalbox.conf with the following parameters: system.samba.enabled=0, system.api.enabled=0 and system.manager.enabled=0
                                  • Set static gamelists through the interface. Again, you should have a good rom list aready working cause new games will not be dinamically included.
                                  PT_BR Retrogaming on Telegram
                                  • Bkg2k
                                    Bkg2k Staff @nwildner last edited by Bkg2k
                                    @nwildner gpu_mem_1024=384 is the default value in latest beta version, and will be in the next release.
                                    EmulationStation is never killed by any OOM manager. It just crash when available memory is too low or too fragmented.
                                    Anyway... there are simple & clever things to do in order to avoid OOM without cutting off half the Recalbox services: DO NOT INSTALL 1080p THEME ON RASPBERRY PI! 🙂 720p maximum for background images.
                                    I have a full system Recalbox and no memory issues when using a 720p theme.
                                    • nwildner
                                      nwildner @Bkg2k last edited by
                                      @bkg2k said in [Theme] Clean Retro:
                                      Yeah, i saw that on Gitlab 🙂
                                      Since the theme creators can't post things here due to copyright issues, and i don't really think they want abandon the 1080p resolution on their theme, guess i'll have to stick with other themes.
                                      • Bkg2k
                                        Bkg2k Staff last edited by
                                        Puting the theme on mega.nz or any other file-sharing system avoid copyright issues.
                                        • recalbox45
                                          recalbox45 last edited by
                                          possible de mettre à jour le thème pour la version 6 de recalbox ? ne marche pas
                                          Goomba 1 Reply Last reply Reply Quote 1
                                          • Goomba
                                            Goomba @recalbox45 last edited by
                                            @recalbox45 Je serais intéressé également car c'est de loin mon thème préféré !
                                            100.8k
