    laggy main menu (x64)
    laggy main x64
    • Jan
      Jan last edited by
      Hello,
      I have a small problem with Recalbox.
      My HTPC is a Dell Optiplex XE with the following specs:
      GPU: AMD Radeon r7 240
      CPU: Intel Core 2 Duo E8400 @ 3GHz
      2x 2GB sticks of DDR3 RAM (I think 1066)
      My main menu looks like a 0-2 FPS slideshow, same problem with emulation.
      I look forward to any reply.
      Jan
        Substring @Jan last edited by
        @jan your gpu is simply not yet supported by recalbox
        joinski 1 Reply Last reply Reply Quote 0
        • Jan
          Jan last edited by
          hm okay, is there a way to install the driver manually?
          • joinski
            joinski @Substring last edited by
            @substring is there a list of supported GPUs?
            Or is it just try & error?
              @joinski that's a mix of kernel version + nvidia drivers version
              101.0k
