    C64DTV (Direct 2 TV) Emulation -AddOn-
    Your discoveries
    c64dtv direct addon
    14234
    • Ratte
      Ratte last edited by Substring
      5 minutes for a new gamingsystem
      https://www48.zippyshare.com/v/2v6HQtDP/file.html (updated archive)
      no binaries needed, all req. files are still included in recalbox
      this archive includes scripts and configfiles for the
      DTV64 system
      https://en.wikipedia.org/wiki/C64_Direct-to-TV
      https://www.youtube.com/watch?v=R_kJOatGqyg
      unlike the computer-system, no keyboard is needed.
      all functions are mapped to the controller.
      the archive includes a sample dtv-scene demo: Misery III by Tristar & Red Sector Inc.
      http://www.pouet.net/prod.php?which=53941
      have fun!
      •Raspberry Pi model: Pi ZeroW
      •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
      •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
      • Secamfr
        Secamfr last edited by
        @Ratte Hello, just install it but it doesn't work for me (RPI 3, Recalbox last version), black screen then back to ES 😕
        Ratte 1 Reply Last reply Reply Quote 0
        • Ratte
          Ratte @Secamfr last edited by Ratte
          @secamfr Hi, new menuentry is visible ...otherwise you should´t get a blackscreen with return to es ...
          Did you set the fileattributes for the files in /usr/bin/scripts/ to 0755 ?
          (scripts/start.sh and the six other files)
          • Secamfr
            @Ratte Yes all files in /usr/bin/scripts/ have 0755 fileattibutes
            I just look in the file dtv64.sh and i see "/usr/bin/x64dtv" ? What is it, a file, a folder ? I don't have this on my recalbox...
            I don't see any binary so how this work ?
            • Ratte
              Ratte last edited by Ratte
              Fix for missing x64dtv binary !!!
              (last time i worked with batoc... and there it is included)
              Please copy the binary to /usr/bin and set attributes to 0755.
              https://www93.zippyshare.com/v/t7F1jcRk/file.html
              • Secamfr
                @Ratte Ok i copy the binary with 0755 fileattributes but don't work again... maybe i need others files ?
                Anyone have try it ?
                • Ratte
                  Thanks for the feedback. I must do a testrun with my old pi.
                  There is currently no support for the rpi3bplus, that i am actually using.
                  I have to make no secret of the fact that I use Batocera for the rpi3b+.
                  The version supports my newer hardware (rpi3b+) and has all binaries integrated.
                  Since the versions are related, I thought that the required binaries are not missing here.
                  OK, found this ...
                  https://forum.recalbox.com/topic/6443/c64-problem-on-4-1-0-unstable
                  Going to dig in the stuff this evening.
                  • Secamfr
                    @Ratte Ok thank you, i'm waiting for the new fix 😉
                    • Ratte
                      @secamfr OK, I found the problem.
                      On my test image it is now up and running.
                      There are more differences between recalbox "buildroot" and recalbox "batocera" than i expected.
                      I will send you a privat link for a testarchive, i dont want to make the same mistake again.
                      Are you willing to do such a testrun?
                      • Ratte
                        UPDATED USER-ARCHIV (12.MAY`18)
                        New install instructions:
                        -=# WinSCP + PuTTY - howto (fresh installed RB 18.04.20) #=-
                        PuTTY (login "recalboxroot" or "linux" on batocera):
                        01.) /etc/init.d/S31emulationstation stop
                        02.) mount -o remount,rw /
                        WinSCP:
                        03.) copy the c64dtv directory from the addon-archiv
                        • C:.. ..\dtv64-addon\etc\emulationstation\themes\recalbox-next
                        to recalbox
                        • /etc/emulationstation/themes/recalbox-next
                        If you prefer the old theme or you are using batocera-linux, take
                        themes/recalbox instead
                        04.) walktrough the new subdirectory and make all fileattributes 0755
                        05.) open the textfile from the archiv
                        • C:.. ..\dtv64-addon\etc\emulationstation\add2_es_systems.cfg.txt
                        mark the complete text and copy&paste it in the recalbox-config at
                        • /etc/emulationstation/es_systems.cfg
                        in the line after <systemList>
                        save the changed configfile
                        At this point we created a new menu entry for the dtv64 system!
                        (currently there is no graphic visible in the next-theme, only the logo-text .. i am workin on it)
                        Now we are going on with adding the files:
                        06.) copy the c64dtv directory from the addon-archiv
                        • C:.. ..\dtv64-addon\recalbox\share\roms
                          to recalbox
                        • /recalbox/share/roms
                        07.) copy the x64dtv binary and the scripts subdirectory from
                        • C:.. ..\dtv64-addon\usr\bin
                          to recalbox
                        • /usr/bin
                        08.) walktrough the new subdirectory and make all fileattributes 0755
                        same for the x64dtv binary
                        09.) copy the required libraries and vice subdirectory from
                        • C:.. ..\dtv64-addon\usr\lib
                          to recalbox
                        • /usr/lib
                        10.) walktrough the new subdirectory and make all fileattributes 0755
                        same for the libncurses.so.6.0 & libreadline.so.7.0 binaries
                        PuTTY:
                        11.) jump to the /usr/lib subdirectory with
                        • cd /usr/lib
                        12.) build the required vice links for the new libraries with
                        • ln -f -b -s libncurses.so.6.0 libncurses.so.6
                        • ln -f -b -s libreadline.so.7.0 libreadline.so.7
                        13.) all operations are done, restart the system with
                        • reboot
                        (required extra step for BATOCERA ONLY!!)
                        batocera-users MUST save the overlay before rebooting with
                        • /recalbox/scripts/recalbox-save-overlay.sh
                        Now it should be up and running ...
                        BR
                        Ratte
                        REQUIRED BIOS FILES ARE:
                        • none (vice includes a dtv-kernal)
                          additonal possible: dtvloader.rom
                          (for customized welcome screens or so on ...)
                        SUPPORTED GAME ROM FILES:
                        • .BIN (2MB DTV FLASHROM IMAGES)
                        • .PRG (SINGLE FILE SUPPORT)
                        • .D64 (1541 DISK IMAGES)
                        • Ratte
                          @substring: thanks for updating the archiv-link in the first posting
                          @all: comments are welcome ... 🙂
                          • Secamfr
                            @Ratte Great job, now we have more commodore on recalbox !
                            • Ratte
                              No more opinions?
                              So I produced a piece of crap.
                              • Gaetan
                                Gaetan Theme moderator @Ratte last edited by
                                @ratte it's really interesting even though I can't try it right now.
                                Maybe you should tag some moderators in your comment to give a signal 🙂
                                • Secamfr
                                  Just finish the addon for Commodore VIC-20 (thanks Ratte!) :
                                  Features :
                                  Support format: .tap, .d64, .prg and .crt
                                  Compatible PAL & NTSC
                                  Auto-detect expansion memory : 3k, 8k, 16k, & 32k
                                  Joystick is configured for 8bitdo SFC30 PRO (you can edit vic20binjoy.conf to change parameters) :
                                  move with D-pad or Left analog
                                  A : Fire
                                  B : Space
                                  X : F1
                                  Y : Virtual Keyboard
                                  Select : Quit emulator (return to ES)
                                  Start : Vice Menu (for expert)
                                  Install the C64DTV addon by Ratte copy all files from this archives,
                                  make all fileattributes 0755 and reboot !
                                  https://mega.nz/#!uYBXUDAa!tC3bvBoFUYUIphoiJMCX6lKB8VPEo54SJB0WVJ2hnZ4
                                  Secamfr 1 Reply Last reply Reply Quote 0
                                  • Secamfr
                                    Secamfr @Secamfr last edited by
                                    Quick fix
                                    https://mega.nz/#!qZoxHa7A!PCLxUcGnP6K_oL5nLVlotaqvhlqyt8aO4Bi7V0Wptis
                                    • Secamfr
                                      Addon for Commodore Plus/4 & Commodore C16 (thanks Ratte!) :
                                      Features :
                                      Joystick is configured for 8bitdo SFC30 PRO (you can edit plus4binjoy.conf to change parameters) :
                                      A : Fire
                                      B : Space
                                      X : F1
                                      https://mega.nz/#!TJwFABJC!ndM9YwD--o98oIuqeMp6bTa2_XWDWmxMiSf2vQ4KAfc
                                      New Version for Commodore VIC-20 :
                                      https://mega.nz/#!vcgxCaKJ!THJ6LnCpIjXeqlFagVX9ZPhMQOjXuQcMr6hs22I8ENY
                                      • Gaetan
                                        Gaetan Theme moderator last edited by
                                        @Ratte , @Secamfr do you think those addons could be integrate in Recalbox ?
                                        • Ratte
                                          I don't mind. It depends on the recalbox staff.
                                          • Gaetan
                                            I don't know who to contact, but maybe @Substring does ?
