    Recalbox hangs on game exit
    recalbox hangs
    3219
    • chris3lx
      chris3lx last edited by
      I have just setup Recalbox on a Raspberry Pi 1, successfully configured my wireless X360 controllers and started playing a few games. However whenever I try to exit a game (hotkey +Start) the system just hangs and I have to pull the power cable to reboot the RPi. I am running the latest stable version 18.04.20 and flashed onto a brand new 32GB MicroSD card.
      Your help would be appreciated.
        Substring @chris3lx last edited by
        @chris3lx what does "hang" mean ? What's displayed ? Can you still reach the webmanager ? Or ssh to your pi ?
        • chris3lx
          Screen goes blank and doesn’t return to Recalbox main menu. Everything is completely unresponsive.
          I haven’t tried logging into Manager or ssh but I can try later
            voljega Banned @chris3lx last edited by
            @chris3lx do you have the latest version ? because there was a bug which was exactly like that corrected in the last one ...
              @chris3lx please try, this would tell if the system is frozen of if es just crashed
              • chris3lx
                I am running the latest version. When I exit a game the screen goes blank, however I can still access the ROM Manager via web browser. I have saved the log files if they are of use?
                chris3lx 1 Reply Last reply Reply Quote 0
                • chris3lx
                  chris3lx @chris3lx last edited by
                  @chris3lx said in Recalbox hangs on game exit:
                  @Substring
                    @chris3lx ES crashed, can you make a support archive once the problem just happened ?
                    • chris3lx
                      chris3lx @Substring last edited by
                      @substring how do i make a support archive?
                        @chris3lx make sure your recalbox is on the network, then go to http://recalbox/help if you.re on windows, http://recalbox.local/help on linux/mac
