    Solved Recalbox on Raspberry pi 3: wifi and gamepad config reset at each reboot
    recalbox wifi gamepad config reset
    1419
    • Cassoulet
      Cassoulet last edited by
      Hello all,
      I have just reinstalled everything on the raspberry pi 3 with the last Recalbox version (18.04.20).
      I start the pi and everything works smoothly, I love it. I configure the PS3 gamepad the wifi and then when I reboot the PI I have to redo every config again both WiFi and the gamepad...
      I am getting mad here.
      How do you fix this?
      Thank you for your generous help 🙂
        OyyoDams Staff @Cassoulet last edited by
        @cassoulet can you make a support archive from the web manager ?
        • Cassoulet
          @OyyoDams Thank you for your time
          Download URL: https://file.ac/vSygs_yEB_M
            OyyoDams Staff last edited by
            @cassoulet said in Re: [Recalbox on Raspberry pi 3: wifi and gamepad config reset at each reboot](/topic/13938/recalbox-on-raspberry-pi-3-wifi-and-gamepad-config-reset-at-each-reboot):
            @OyyoDams here you go, thank you for your time.
            So,
            I see you have an external hard drive, but this drive is not mounted. Please follow this guide to solve it.
            Then, let me know if it's better.
            • Cassoulet
              @OyyoDams I have the impression that it fixed now.
              Thank you very much for your help 🙂
                @cassoulet you're welcome 😉
