    Solved PS4 controller xu4
    GamePad/GPIO/USB encoder
    ps4 xu4
    4992
    • Retrobox
      Retrobox last edited by
      Hello.
      This question is for Odroid xu4 users. Does anyone could pair a PS4 bluetooth controller? I can only use the controller with a usb cable connected.
      Thanks.
        OyyoDams Staff @Retrobox last edited by
        @joseluis Hi, of course it works, you need a bluetooth USB dongle because the XU4 has no internal bluetooth.
        • Retrobox
          Retrobox last edited by Retrobox
          @OyyoDams Hello. I have the Odroid Bluetooth Module 2 connected but nothing happens when I try to pair the xu4 with a ps4 controller. Any idea?
          Thanks for your help
            OyyoDams Staff @Retrobox last edited by OyyoDams
            @joseluis first, be sure your BT controler works with Recalbox.
            Then:
            • if you have a real PS4, turn it off
            • turn on Recalbox
            • turn on your PS4 controller
            • hit the RESET switch on the back of the controller
            • the controller turns off
            • turn on the controller again with HOME + SHARE at the same time for a while, until the blue light blinks
            • in Recalbox, pair it in bluetooth options
            • Retrobox
              @OyyoDams Unfortunately I have done all the directions you gave me but nothing happened. I contacted Odroid developers and they said: "We think Recalbox Kernel or Bluez stack has no proper driver for PS4...Report the issue to the Recalbox developers.". I have watched videos from people pairing ps4 controllers on a Raspberry pi 3 but not on a xu4. Any idea about what is happening?
              Thanks again
              OyyoDams Substring 2 Replies Last reply Reply Quote 0
                @joseluis I do have a PS4 controler and a XU4, and it works. But I use a USB BT dongle, the one available on the recalstore. That's why I told you "first, be sure your BT controller works with Recalbox". I don't know if the "Module 2" works. Maybe @Substring can answer.
                  Substring @Retrobox last edited by
                  @joseluis are you sure you BT dongle works ok on Recalbox ? can you SSH and then give me the result of hciconfig ?
                  • Retrobox
                    @Substring this is the result:
                    hci0: Type: BR/EDR Bus: USB
                    BD Address: 00:1A:7D:DA:71:13 ACL MTU: 310:10 SCO MTU: 64:8
                    UP RUNNING PSCAN ISCAN
                    RX bytes:595 acl:0 sco:0 events:35 errors:0
                    TX bytes:1422 acl:0 sco:0 commands:35 errors:0
                      @joseluis that sounds good. You can try to follow this procedure to pair it in command line. Then feel free to post here the result.
                      • Retrobox
                        @OyyoDams @Substring You are geniuses. Problem solved. Thanks for the time and patience!!!
                          @joseluis Thanks for your feedback!
                          I'm pretty sure it should have worked from Emulationstation. Anyway have fun 🙂
                          101.4k
