    Solved daemon(startup script) not executing what ssh does
    daemonstartup script executing ssh does
    2504
    • MinZe
      MinZe last edited by MinZe
      Hello, my custom start script doesnt execute correctly what my ssh does... its about rclone (uses rsync) and even though it does the infinite and execute the echo and the recallog, the rclone's commands don't, while executing the same file over ssh allows me to do so.
      My daemon script works because it calls the other script with the command.
      the script that the daemon calls:
      #!/bin/bash
      rclone copy /recalbox/share/saves/ gdmedia:rpi > /dev/null
      edit: I tried without !/bin/bash too
        voljega Banned @MinZe last edited by
        @minze Hello minze think it would be better if you used one subject for all your questions regarding your script.
        For rclone, don't know it enough to help, sorry
        MinZe 1 Reply Last reply Reply Quote 0
        • MinZe
          MinZe @voljega last edited by
          @voljega well the other posts' main problem are solved, but as the main thing is not, I haven put [solved] in the title
            Substring @MinZe last edited by
            @minze solved is added through topic tools, you can't edit the title.
            Regarding your problem : put the full path to the rclone binary at least. How have you demonized it ?
            • MinZe
              MinZe @Substring last edited by
              @substring About the rclone, I haven't, I added the full path for rclone and still doesn't work like it does on ssh. The script that calls rclone I have done chmod u+x and it's in /etc/init.d/
              Is there someway to see the actual recalbox terminal without having to exit emulationstation and/or from the pc?
                @minze plug a keyboard on the pi, press F4 then ALT+F2
                • MinZe
                  @substring Thanks to that I've found that on the daemon, it searched for one .conf on another place. Now I've solved and it's fully working without problem.
                  If I have time, this weekend I'll make the tutorial for recalbox. If I do it, it'll be at least for GDrive, maybe for onedrive too (can't promise anything as it should be almost the same).
