    Solved [bash/python] know if wifi is connected
    [bashpython] wifi connected
    • MinZe
      MinZe last edited by
      Is there anyway to know if wifi is connected?
      I need to run a script once wifi is connected for the first time, doing it on the startup it seems that it doesn't work because wifi is not connected yet
        voljega Banned @MinZe last edited by
        @minze better detect that there a connection at all no ? all people don't use wifi ?
        you'll have to use a custom script launched after the emulationstation script I suppose, look into /etc/init.d
        • MinZe
          What I wanted to test was if it was connection it didn't matter if it was through wifi or ethernet, I have found an script that I will post here if it works.
            Substring @MinZe last edited by
            @minze just ping your gateway, or check if ifconfig returns anything other than loopback
