    Problem with recalbox 18.03.30
    recalbox 18.03.30
    12805
    • Mr. Kilroy
      Mr. Kilroy last edited by Mr. Kilroy
      Hello!
      1. I did not understand how it will be updated before 18.03.30. It was necessary to reinstall this OS from the image from scratch. I started, I chose my language - RUSSIAN. But it does not appear correctly, how can I fix the problem? Help me please
      alt text
      1. The second problem with the resolution in the emulators.
        Recalbox and Kody work fine in 1080p. And when I start the game, then from the right side of the screen there is a vertical bar (about 2 inches wide) on the entire screen. How to fix it?
        Substring @Mr. Kilroy last edited by
        @mr-kilroy Privet !
        Russian will be fixed in the next release.
        Regarding display : i'm not sure i understand the problem. What's the size and native resolution of ypur monitor ?
        Mr. Kilroy 1 Reply Last reply Reply Quote 0
        • Mr. Kilroy
          Mr. Kilroy @Substring last edited by Mr. Kilroy
          @substring Privet 🙂 monitor 1920x1080.
          Recalbox menu and Kody work fine, in full screen.
          But when the game starts, the resolution changes and a black bar appears on the right, from which I can not get rid of.
            @mr-kilroy games are 4:3 for most of them, not 16:9 + we switch to 720p for games
            • Mr. Kilroy
              @substring those himself rekal box works in 1080p, and emulators run under 720p?
                @mr-kilroy 720p for games, yes, for better performance
                • Mr. Kilroy
                  @substring And can you somehow center the image? because the sidebar interferes 🙂
                    @mr-kilroy the monitor is supposed to do that automatically
                    • Mr. Kilroy
                      @substring The fact of the matter is that there is not. I say that the frames (in my case, the strip) are black 🙂
                        @mr-kilroy eventually force to 1080p for everywhere by editing recalbox.conf and setting global.videomode=default
                        • Mr. Kilroy
                          @substring Thanks, I'll try.
                          And when will there be an update for Russian localization? Or it is possible as that most to correct?
                            voljega Banned @Mr. Kilroy last edited by
                            @mr-kilroy april 20th
                            Mr. Kilroy 2 Replies Last reply Reply Quote 0
                            • Mr. Kilroy
                              Mr. Kilroy @voljega last edited by
                              @voljega @Substring Thx
                              • Mr. Kilroy
                                @Substring @voljega
                                Still a question, whether the emulator Nintendo DS works. If so, how to install it?
                                  voljega Banned @Mr. Kilroy last edited by voljega
                                  @mr-kilroy please read wiki and compatibility related to platform, it's only available on x86/x64
                                  • Mr. Kilroy
                                    Mr. Kilroy @voljega last edited by Mr. Kilroy
                                    @voljega said in Problem with recalbox 18.03.30:
                                    please reda wiki and compatibility related to platform, it's only available on x86/x64
                                    probably you had in mind the table?
                                    https://github.com/recalbox/recalbox-os/wiki/Board-Compatibility-(EN)
                                    1. In RetroPie (and Lakka) this emulator works, I understand you have difficulties with it? 🙂
                                    2. and another question. what is LIBRETRO, RETROARCH, emulation station. I do not fully understand. Explain, please 🙂
                                      @mr-kilroy we add emulators if they can be reasonnably enjoyable. We could add DS on pi3, but at hardly 15fps, it's not worth
                                      EmulationStation is the software where you choose which game to play
                                      Retroarch is a a multi emulator. Each emulator in itself is called a core.
                                      Libretro is a "programming technology" to make any emulator work with retroarch
                                      • Mr. Kilroy
                                        @substring Thx. Those differences will not be what I choose, Recalbox or Lakka?
                                          @mr-kilroy i 'can't help you for your choices, lakka is also a great system, i'm quite close to lakka's developpers 🙂
                                          Mr. Kilroy ShadowFrenchy 2 Replies Last reply Reply Quote 0
                                          • Mr. Kilroy
                                            @substring THX. It's just that Lakka does not have Kodi, but I do not know how to install it. While I'm sitting on ReсalBox, there are games in it and online cinema 🙂
