    Remap Hotkeys
    remap hotkeys
    • cristian-torres-mqz
      cristian-torres-mqz last edited by
      Hey there! Im just installed recalbox running away from retropie. Its amazing and very easy but I dont have select button and anyone free so I want to use a hotkey command to "insert coins". Is is possible? Thanks fellas
      • digitaLumberjack
        Hi, the select button is use in all emulators to add coins. So here you don't have choice you must map select. If you map Hotkey on the same button you mapped Select, the issue is that on some games you won't be able to add coins... Sadly I have no silver bullet solution for you...
          And for information, this bug is not specific to recalbox, but retroarch. So this impact every OS using it. Actually an issue is discussed, but I don't know if they will find a hack to solve it... So wait and see. https://github.com/libretro/RetroArch/issues/2230
