    Composite Recalbox 18.03.16
    composite recalbox 18.03.16
    • Daan lageschaar
      Daan lageschaar last edited by
      Hi,
      I'm wondering how to use composite in Recalbox 18.03.16.
      First you had to press shift when starting up and that would bring you to a little menu where you could press 3 or 4 so you could see something on your CRT tv. But this little menu has been removed (at least when you start up the raspberry pi).
      Is there any other way to get to this menu or do you have to configure it in a different way now?
      Thanks in advance,
      -Daan
        Substring @Daan lageschaar last edited by
        @daan-lageschaar hi
        This depends if you wish autodetection or forced sdtv mode. But you'd need to edit /boot/config.txt according to the wiki
        100.8k
