    how to swap disc c64
    Emulator Arcade/PC/Console
    swap disc c64
    8552
    • giubbe de Giubbix
      giubbe de Giubbix last edited by
      requirements
      a) working mouse in vice gui
      b) RetroK_KP_PLUS button assigned to the joypad
      c) physical keyboard (for symbol ")
      procedure (tested with two disks)
      1. start disc 1
      2. activate the Vice GUI
      3. to select "attach to fliplist"
      4. in DF8 select disc 2
      5. press "resume" in Vice GUI (the emulator restart)
      6. activate the Vice GUI
      7. in DF8 select disc 1
      8. press "resume"
      9. write load"*",8,1
      10. start the game 🙂
      11. when you need to change the disk, press retrok_kp_plus
        each press of retrok_kp_plus swap the disk
      chacs 1 Reply Last reply Reply Quote 1
      • chacs
        chacs @giubbe de Giubbix last edited by
        @giubbe-de-giubbix said in how to swap disc c64:
        requirements
        1. start disc 1
        8. press "resume"
        i have tried with Winter Games (2 disc games) but that doesn't work.
        i start the game from recalbox, while the game is loading, i activate the Vice GUI.
        i select "attach to fliplist", i select Winter Games side B file in DF8, i press "resume".
        the emulator restart. i activate again the Vice GUI. The "attach to fliplist" check button is still selected. I select Winter Games side A file in DF8 and i press "resume".
        The emulator restart. I write load"*",8,1 and i press return but the message "file is not found" is displayed.
        Do you think i made a mistake ?
        giubbe de Giubbix 1 Reply Last reply Reply Quote 0
        • giubbe de Giubbix
          giubbe de Giubbix @chacs last edited by
          @chacs
          I just tried it and it works.
          disc1 -> "winter games disc1"
          disc2 -> "winter games disc2"
          Sorry, I could not replicate the problem
          With other games, "file is not found" error message appears when the disk type is incorrect.
          chacs 1 Reply Last reply Reply Quote 0
          • chacs
            @chacs
            That works ! i used zip file instead of d64 file. Thank you for your help 🙂
            Do you think there is a way to create once the fliplist to avoid reselecting it each time before playing a game ?
            • giubbe de Giubbix
              @chacs
              I happy that it works.
              I tried to save the settings, but I could not.
              I hope the next version supports multi-disc zip
              1 Reply Last reply Reply Quote 3
              • ekilla
                ekilla last edited by
                THAAAANKS a lot ! 🙂
                • giubbe de Giubbix
                  With recalbox 6 it is easier to solve using m3u files.
                  https://github.com/libretro/vice-libretro (M3U Support and Disk control)
                  twh_pi 2 Replies Last reply Reply Quote 1
                  • twh_pi
                    twh_pi @giubbe de Giubbix last edited by
                    h
                    So how exactly is this supposed to work with m3u? could you please post an example ?
                    • twh_pi
                      @giubbe-de-giubbix Let's say with "Pirates".
                      Pirates! (Disk1).D64
                      Pirates! (Disk2).D64
                      Pirates!.m3u
                      (containing to lines with
                      Pirates! (Disk2).D64)
                      Is this supposed to appear in the gameslist.xml?
                      • giubbe de Giubbix
                        giubbe de Giubbix @twh_pi last edited by
                        @twh_pi
                        You have to do a manual search for the name m3u. Then hide the games Pirates! (Disk1).D64 e Pirates! (Disk2).D64
