    Buttons are pressed without touching them!!
    GamePad/GPIO/USB encoder
    buttons are pressed touching them
    7
    50
    16377
    • saver
      saver last edited by
      Hello i am new here. I have a major problem. My set up: Bartop arcade cabinet - raspberry pi3b - XinMo 2 player arcade controller (18 buttons) - recalbox. Everything was ok until yesterday when my nephew while playing pressed all buttons together many times. After that the buttons are pressed without touching them. I have the same problem if i use only keyboard with the xinmo unplugged. Please can someone help me.
        Substring @saver last edited by
        @saver reinstall ? I have no darn idea about what else to do
        saver 1 Reply Last reply Reply Quote 0
        • saver
          saver @Substring last edited by
          @substring i have already done but nothing changed. Maybe the problem is raspberry pi. Can i reboot or reprogramme or something like that the pi? Otherwise i can't think where is the problem
          • saver
            saver @saver last edited by
            I also tried another sd card with another image but again the same problem. On the pi i have only the screen hdmi cable the power supply and the keybord
              voljega Banned last edited by voljega
              @saver it's likely you have some autofire button and/or combination of your buttons on your xinmo if such thing exists, and your nephew activated it, check the doc
              or your connections were crappy and by pressing a bit violently on the buttons, your nephew created a shortcut, check connections of your buttons
              • saver
                @voljega but i have the same problem with xinmo buttons unplugged. Only with the keybord. I also tried ps3 controler and again the same problem. I am desperate. Maybe i have to buy a brand new raspberry pi
                  @saver with a bluetooth PS3 pad you mean ?
                  • saver
                    @substring sorry ps1 usb controler not bluetooth
                      @saver so you have a mad usb uh ? Does the same happen if you unplug ecerything but power supply, hdmi, and you try raspbian ?
                      • saver
                        The problem is solved fortunately. I tried to connect the hole system with my tv screen via hdmi and everything was OK. So i replaced the hdmi cable of the cabinet with the tv hdmi cable and everythik work perfect. Although i don t think this was the problem. Thank you very much for your time.
                        • saver
                          How can i upload a video to show you the problem? I am desperate. I have tried everything. I have replaced all the parts of my setup but i have the same problem.
                            @saver run evtest for each input and see which one is doing that mess
                            • saver
                              @substring can you please give me directions how to run evtest because i m not so familiar with this. Thanks in advance
                                @saver ssh to your recalbox, type evtest, then test input 0 to see if there are some events happening by themselves with no user action. Press CTRL+C, try then with input 1 etc ...
                                In the end, give me the name of the input(s) that had ghost inputs
                                • saver
                                  @substring thank you very much but i need additional help. I run evtest then i press 0 and then i don t know what to do. How can i understand if some events are happening by themselves with no user action?
                                    @saver they'd just pop after the description of known events the input reports
                                    • saver
                                      @substring i run evtest via putty and i took a photo to show you the results. I couldn t copy the text. How can i upload a photo please?
                                      • saver
                                        @saver said in Buttons are pressed without touching them!!:
                                        https://postimg.cc/image/iaejz53yd/
                                          @saver nothing happens after the "Testing..." You should try events 2 and 3. By tthe way, are you using the GPIO controllers as you have a xinmo ?
                                          • Andrei
                                            Andrei last edited by
                                            I got the same problem but only in Kody, with "Zero delay" arcade joystick
