    Back to ES with HDMI TiMING
    • wadehavens
      wadehavens last edited by wadehavens
      I guess I'm confused. I want all my emulators to boot using
      hdmi_timings 1600 1 70 150 215 240 1 4 4 15 0 0 0 60 0 32000000 1
      And then boot back to ES using
      hdmi_timings 320 1 0 30 50 240 1 6 1 18 0 0 0 60 0 6400000 1
      In stead of acting like I know what I'm doing I'll just ask,
      How do I accomplish this?
      Thanks!!
        Substring @wadehavens last edited by
        @wadehavens create your main hdmi timing in the config.txt as usual.
        For es, edit recalbox.conf and set system.es.video to hdmi_timing blablabla. Also set global.videomode euther auto (if it's lentionned in the recalbox.conf) or default. You can also set some videomode per cinsole if you wish
        • wadehavens
          Ok, I did exactly what you said to do and it didn't work. It boots to the resolution I want but stays in that resolution after it returns to ES.
