    Update Frozen
    update frozen
    2932
    • rocketbomb
      rocketbomb last edited by
      I had latest recalbox now today i got notification to update so i started updating and download is right now frozen at 43%. no key is working. is it updating in background ? will it be safe to reset my recalbox in current state?
      https://imgur.com/a/BDvi2
        Substring @rocketbomb last edited by
        @rocketbomb no, remove the files in the upgrade folder
        • rocketbomb
          i deleted all files from upgrade folder through an live cd i'm ending up at black screen after colored screen
            @rocketbomb 43%, download ... Do you mean the black screen with the white progress bar saying "Upgrading please wait" ? this is no download, this is the real upgrade
            Please use the answer button to notify me, or I can miss your reply
            • rocketbomb
              thanks , actually my recalbox blew after update fail. i deleted all files in upgrade folder through linux but it wont boot at all after colored screen. then i had to install from scratch. i had back up of all my stuff. but in this latest recalbox NextLevel 2.3 theme is not working....
              Substring Gaetan 2 Replies Last reply Reply Quote 0
                @rocketbomb themes are supposed to be backward compatible, ask @gaetan
                • Gaetan
                  Gaetan Theme moderator @rocketbomb last edited by
                  @rocketbomb Hi! The theme Next Level is working fine after the update.
                  What is not working on your Recalbox ?
                  Maybe you should download it again and try it.
                  rocketbomb 1 Reply Last reply Reply Quote 0
                  • rocketbomb
                    rocketbomb @Gaetan last edited by
                    @gaetan thanks next level is working now. now in kodi classic steampunked theme isnt working very sad
