    18.03.16 - Moonlight
    Emulator Arcade/PC/Console
    18.03.16 moonlight
    10590
    • nwildner
      nwildner @Substring last edited by
      @substring Thanks.
      I was going to do right now(Gitlab is not allowed at my workplace)
      PT_BR Retrogaming on Telegram
      • Gimpi
        Gimpi @Substring last edited by
        @substring Sorry for my dumb ess 18.03.30 is Out and installed moonlight still dont realised my Bluetooth controller
          Substring @Gimpi last edited by
          @gimpi i don't understand
          Gimpi 1 Reply Last reply Reply Quote 0
          • Gimpi
            @substring the Update said some fixes in the moonlight Installation but my Bluetooth controller will Not Work while streaming any USB plugged Controller worked
              @gimpi i haven't tried with any bluetooth controller in fact
              • Gimpi
                @substring ok in the "christmas" recalbox Patch it worked Like a Charm with an Bluetooth Hmm ok im Just trying now
                  @gimpi because moonlight had to be updated since to be compatible with GFE 3.12. But the pad configuration routines changed. I'll try and see if the dev how this goes. Which pad doesn"t work ? can you provide a support archive ?
                  • Gimpi
                    @substring its an third Party ps3 bluetooth controller from "big ben"
                    How Do i create an Support archive? Can try it after Work tonight
                      @gimpi start recalbox, go to http://recalbox/help or http://recalbox.local/help if you're on MAC/Linux
                      Gimpi 2 Replies Last reply Reply Quote 0
                      • Gimpi
                        @substring sorry a day later but last night im was to tired from work but here the support link https://file.ac/hTP96AeqSDQ/
                        • Gimpi
                          @substring b*mb ?
                          any fixing tipps ?
                            @gimpi could find much of a source of a problem, haven't had time to dig much further
                            100.3k
