    Solved controller issues with psx emulator
    Your discoveries
    2689
    • kingofsteam
      kingofsteam last edited by
      so im using the psx emulator and cant get it to work with my xbox 360 controller or xbox one controller. i bought a Beboncool controller to and just like the others it wont sense the right joystick all of the other buttons work fine. if anyone else has had this problem please tell me and help the best you can thank you .
        voljega Banned @kingofsteam last edited by
        @kingofsteam which game are you trying ? are you sure it is using the right joystick ?
        kingofsteam 1 Reply Last reply Reply Quote 0
        • kingofsteam
          i am playing ape escape right now
          • kingofsteam
            kingofsteam @voljega last edited by
            @voljega
              paradadf Staff @kingofsteam last edited by
              @kingofsteam you are teying with a game with special control settings needed. Look for ape escape on the forum and you‘ll see the exact configuration you need on retroarch to make it playable.
              • kingofsteam
                kingofsteam @paradadf last edited by
                @paradadf thank you so much I did what you said and I found out what i needed to do.
