    Beta7 N64 roms issues
    beta7 n64 roms issues
    6
    7
    2937
    • aaroncastello123
      aaroncastello123 last edited by
      Hello! I'm trying to play to Zelda Majorask mask or Zelda Ocarine of Time, in beta7, and I can't play to it because the screen is black and I should restart the raspi2 to return to the recalbox menu. I tryed with roms with .n64, .z64 and the other extension compatible with recalbox. Is anyone having this issues like me? Has anyone solved it? thanks
      • jose-luis-reyes
        jose-luis-reyes last edited by
        Me too since beta versions...
        • cluf20
          cluf20 last edited by
          Zelda don't work with the pluging n64. You can try to enable the rice pluging in the recalbox.conf file
          • aaroncastello123
            What I should do to enable the rice pluging? I'm noob 😞
              Hello in recalbox.conf : https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-(EN) like this
              ## N64 core (n64,rice)
              ## The recommanded plugin is n64, but if your game don't start, try rice (example Zelda Ocarina of Time, Banjo Kazooie, ...)
              ;n64.core=n64
              ;n64.videomode=CEA 4 HDMI
              ## If you use rice core, set mode 480p as below
              n64.core=rice
              n64.videomode=CEA 3 HDMI
              • mike-luetjens
                mike-luetjens last edited by
                My Question here is what to enter while running the rice core on RCA? I also can´t set the resolution to 480, I think RCA runs with 576i ? It worked when i set the variable to globaldefault, not sure if taht had any impact at all. Mario Tennis finally starts, also both Zelda, but its like 3-4 FPS.   Any Idea how to pimp that? is Performance over HDMI and 480p better?
                ;n64.core=n64
                n64.core=rice
                  Hello are you using a CRT screen? you can try to edit your recalbox.conf like that :
                  n64.core=rice
                  n64.videomode=CEA 2 HDMI
                  then inside your /recalbox/configs/mupen64/mupen64plus.cfg add your screen resolution here :
                  [Video-General]
                  # Use fullscreen mode if True, or windowed mode if False
                  Fullscreen = False
                  # Width of output window or fullscreen width
                  ScreenWidth = 1280
                  # Height of output window or fullscreen height
                  ScreenHeight = 720
                  # If true, activate the SDL_GL_SWAP_CONTROL attribute
                  VerticalSync = False
                  In this example, it is setup for a HD resolution of 720p.
