    Insert coin via IR (Remote Control)
    insert coin remote control
    2706
    • angelobrg
      angelobrg last edited by
      Hi!
      Is it possible in the recalbox to put an IR device so that I can somehow insert the coins into the games via remote control?
      • Dragu
        Dragu Banned last edited by
        @angelobrg
        The "Insert Coin" is nothing else than the Select key. That you must anyway define on your remote control.
        • angelobrg
          but then I would have besides the traditional 2 joysticks (usb) would I have a third "control" via IR? And in this one button to add credits in the machine, would this?
          • Dragu
            That just depend of you. If you dont install 2 Select buttons or make like me a switch inside coindoor to choose freegame. I have this switch to choose Select Button (then illuminated) or coin insert. I put both select input on one relay. If you add remote control 1 or 2 channels with the relay output to the select connection, you can make it remote, sure.
            angelobrg 1 Reply Last reply Reply Quote 0
            • angelobrg
              angelobrg @Dragu last edited by
              @dragu said in Insert coin via IR (Remote Control):
              Can you explain me better this relay question?
              • Dragu
                Sure, this is my connection of the coin acceptor in my bartop
                alt text
                • angelobrg
                  Thanks!!!
