    Unsolved Startup script not running after following wiki
    startup script running following wiki
    • Tolley
      Tolley last edited by
      I followed the guide from the wiki https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN) and my script doesn't run on boot. I placed it in /etc.init.d/ and named it S97osmc.sh. It mounts a partition then copys a file called osmc.txt to the mounted partition and then renames autoboot.txt. I am running OSMC, Raspbian and Recalbox in noobs multiboot. I am using a raspberry pi 3 and my recalbox verson is 18.02.09 (according to system settings)
      S97osmc.sh:
      #!/bin/bash
      cd ~
      echo 'Attempting Mount'
      mount /dev/mmcblk0p1 ~/temp
      echo 'Attempted Mount'
      echo 'Copying osmc.txt'
      cp /etc/init.d/osmc.txt ~/temp/autoboot.txt
      echo 'Copyed osmc.txt'
      echo 'Done!'
      osmc.txt:
      boot_partition=8
      Thanks in advance for any help
        Substring @Tolley last edited by
        @tolley does it run whe' you start it manually ? Have you chmodded it the right way ? Does ~/temp exist ?
        • Tolley
          Tolley last edited by Tolley
          @Substring Oops totally forgot about chmod, temp does exist and when i run it manually it works. After chmodding it still doesn't work.
            OyyoDams Staff @Tolley last edited by
            @tolley Try to put the full temp path instead of ~/temp
