    Solved Pi3 Won't Pick Up 18.02.09 Update
    pi3 wont pick 18.02.09 update
    9553
    • miso117
      miso117 last edited by
      It seems to have hung in the same place... I am going to reinstall from scratch. I have been using Recalbox for a couple years now, I have a RPI2 and for Christmas got a RPI3. I can't remember if this was the first load or if it was a load and upgrade on the newest PI, but either way, something is jacked up.
      I backed up my ROMs and am going to do a fresh install. If I still see the date issue after I will let you know.
      I really appreciate the help and info, you all rule!
      • miso117
        Did a fresh etch from the newest image and once Recalbox was up I SSH'd to it and #date gave me the correct time.
        It had to be something with the last build, or my SD card... Not sure which, but it is resolved now. Thanks everyone. I so appreciate this community!
        • Del007
          Del007 last edited by
          Hi all,
          I have a pretty same issue. I can't update to 18.02.09. The ping works fine but when i run the command bash -x /recalbox/scripts/upgrade/recalbox-upgrade.sh canupgradeI have the following error at the end : 0curl: (7) Failed to connect to recaleur-archive-prod.recalbox.com port 9443: Connection refused
          Any idea ?
          Thank you
          • Shira
            Shira last edited by
            I'm having a similar issue after I tried a beta version a while ago: https://forum.recalbox.com/topic/12240/testers-wanted-network-share-over-wifi
            bash -x /recalbox/scripts/upgrade/recalbox-upgrade.sh upgrade
            • COMMAND=upgrade
            • [[ -z upgrade ]]
            • BINDIR=/recalbox/scripts/upgrade/
            • SYSTEMSETTINGS='python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc'
            • RECALBOX_SYSTEM_DIR=/recalbox/share/system
              ++ cat /recalbox/recalbox.version
            • INSTALLED_VERSION='292-wifi-aft (2ce937e1) 15982104 rpi3 2018/01/10 08:14:58'
              ++ cat /recalbox/recalbox.arch
            • ARCH=rpi3
              ++ python /usr/lib/python2.7/site-packages/configgen/settings/recalboxSettings.pyc -command load -key updates.type
            • UPGRADETYPE=stable
            • SERVICE_URL=https://recaleur-archive-prod.recalbox.com:9443
              ++ /recalbox/scripts/upgrade//../system/uuid.sh --uuid-file /recalbox/share/system/uuid
            • UUID=c7553d05-d17d-4683-baab-c5c9f26091b3
            • [[ stable == \b\e\t\a ]]
            • [[ stable == \u\n\s\t\a\b\l\e ]]
            • '[' upgrade == canupgrade ']'
            • '[' upgrade == upgrade ']'
            • [[ stable == \s\t\a\b\l\e ]]
              ++ /recalbox/scripts/upgrade//recalbox-canupgrade.sh --from-version '292-wifi-aft (2ce937e1) 15982104 rpi3 2018/01/10 08:14:58' --service-url https://recaleur-archive-prod.recalbox.com:9443 --arch rpi3 --uuid c7553d05-d17d-4683-baab-c5c9f26091b3
              % Total % Received % Xferd Average Speed Time Time Time Current
              Dload Upload Total Spent Left Speed
              0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
              curl: (22) The requested URL returned error: 400 Bad request
            • UPGRADE_URL=
            • [[ 22 != \0 ]]
            • exit 1
              OyyoDams Staff @Shira last edited by
              @shira Try the following:
              Edit /recalbox/recalbox.version and replace the content with 18.02.09
              • Shira
                @oyyodams said in Pi3 Won't Pick Up 18.02.09 Update:
                18.02.09
                Tried that and it started upgrading, restarted, got the msg about system being upgraded but it got stuck at 36% forever, restarted.. now it won't boot. I will do a fresh install I guess.
                100.3k
