    Audio to Bluetooth Speaker?
    audio bluetooth speaker
    5217
    • nwsw
      nwsw last edited by
      Hi,
      I'm using the latest Recalbox build with a Raspberry Pi 2 B inside of a c**ktail cabinet. I've got it all working with split screen and controls working, but I want to output audio to my nearby Bluetooth speaker. Is it possible? I've plugged in a Linux compatible USB Bluetooth adapter and I'm able to pair a PS3 controller, so I just need to determine how to pair to my Bluetooth speaker and output sound. I've seen some tutorials with pulseaudio and RetroPie, but I'm not sure if they would work. Any thoughts? Thanks!
        Substring @nwsw last edited by
        @nwsw we don't support pulseaudio. And using bluetooth for audio will give you some delay in sound, I'm not sure it's worth
        nwsw 1 Reply Last reply Reply Quote 1
        • nwsw
          nwsw @Substring last edited by
          @substring In that case, any suggestions on how to hook up my Pi to my Ms. Pac Man c**ktail's internal speaker? It has two traditional speaker crimp connectors similar to a car speaker. Is it possible to output audio through the Pi's 3.55mm audio to this? Thanks!
          • sag508
            sag508 last edited by
            This post is deleted!
              @nwsw i have no idea how these connectors look like, but it's basic electronics. I guess you could simply do the right cutti gs with a 3.5 jack cable
              • RichardB6
                RichardB6 Banned last edited by RichardB6
