    When will strict keyboard support come?
    GamePad/GPIO/USB encoder
    strict keyboard
    1555
    • StressTester
      StressTester last edited by
      So I love doom and want to play it with a keyboard, NOT A JOYSTICK. I am ripping my hair out trying to figure out how to make this work, and there probably is a solution but it is way too much effort to accomplish, what should be something simple and built in with the early versions of recalbox. Will keyboard only support for games be a thing in future updates?
      Substring voljega 2 Replies Last reply Reply Quote 0
        Substring @StressTester last edited by
        @stresstester Recalbox itself won't map keyboards and never will. Some emulators do handle it on their own, we don't limit that.
        With which emulator are you trying to play doom ? dosbox or retroarch ?
          voljega Banned @StressTester last edited by
          @stresstester you can fully play doom with keyboard on dosbox
          • StressTester
            Thanks for the reply. My recalbox is running on a raspberry pi 3. I eventually got Doom running in DosBox but it's like 15 frames per second, its not really playable. So the only realistic option is to use prboom (good frame rate) but that is where I can't get the keyboard working.
              @stresstester hmmm if U remember well, Doom should run well on dosbox, maybe you have to tweak the conf file
                voljega Banned last edited by voljega
                @stresstester hmmm if I remember well, Doom should run well on dosbox, maybe you have to tweak the con fil
                100.7k
