    Help with led light setup
    help led light setup
    • rommel1940
      rommel1940 last edited by
      PLEASE HELP I IM NEW TO RECALBOX AND IM TRYING TO INSTALL AND SETUP A LED STATUS/POWER LIGHT. ITS A BIT DIFFERENT THAN RETROPIE . A step by step would be very much appreciated. Thank you
      • Oscar 1st Instant
        Oscar 1st Instant last edited by
        I would recommend getting a resistor for the positive (330Ω) afterwards I solved this issue by going into the "Config" file in the sd-card (connected to pc) and adding the line " enable_uart = 1 " at the end. (Use notepad to open config file) Best of luck!
        -Oscar
        Raspberry Pi 3 Model B
        RecalBox 18.02.09
          Substring @Oscar 1st Instant last edited by
          @oscar-1st-instant which gpio pin have you used ?
          Oscar 1st Instant 1 Reply Last reply Reply Quote 0
          • Oscar 1st Instant
            Oscar 1st Instant @Substring last edited by
            @substring GPIO 8 for positive and GPIO 39 for GND
