    Solved How to disable mouse acceleration
    GamePad/GPIO/USB encoder
    2326
    • mjh
      mjh last edited by
      Have done spinner from old wireless mouse. Would like to disable mouse acceleration to get better playing experience in Arkanoid for example.
      My problem is, can´t find the proper folder of mouse driver conf. file.
        Substring @mjh last edited by
        @mjh in which emulator do you want to disable it ?
        • mjh
          mjh last edited by
          In MAME.
          Looking for more accurate response for example:
          • Tempest
          • Arkadoid
          • Bombbee
            etc...
            @mjh been searching a bit : i haven't found anything on libretro nor on the OS itself, unless you're running on a PC. But for pi/odroid, i have no lead
            • mjh
              mjh last edited by
              Running Rpi3.
              Can´t locate either.
              Not too familiar with pi....
              • mjh
                mjh last edited by
                usbhid.mousepoll=2 to boot/cmdline.txt
                solved my problem. Now responding nicely.
