    Amiga Analogue Controls
    amiga analogue controls
    2043
    • roman126
      roman126 last edited by roman126
      Is it easy / possible to set up controls for Amiga to use Analogue Sticks?, I use a PS4 wired controller, the analogue stick works for all the emulators i use in Reclbox except the Amiberry / Amiga emulation, only the digital direction pad works correctly, it appears the analogue up and down works, but not left & right? I see controls can be set via a custome UAE file, I downloaded the examples from Github and didn't really understand what i need to do.
      Had a play with custom controls in the GUI but this didn't seem to help either.
      It would also be great if you could re-assign jump in some games to a button, i find it awkward to press the digital up to jump then digital left or right to move.
      On my PS4 controller fire in all emu is X (B on SNES), but in Amiga emu this moves to Square on the PS4 (Y on SNES)
      Thx in advance!
        Substring @roman126 last edited by
        @roman126 tha's an emulator bug regarding any SONY pad, sadly
        roman126 2 Replies Last reply Reply Quote 0
        • roman126
          roman126 @Substring last edited by roman126
          @substring strange, as my PS4 analogue sticks worked in Amiberry in Retropie?
          • roman126
            @substring yeah, just paired a Wii U Pro Bluetooth Controller and the analogue sticks work as predicted!
            Any way of assigning the ‘Up’ function to a button?
              @roman126 it is all preconfigured, i'm not sure
                voljega Banned @roman126 last edited by
                @roman126 said in Amiga Analogue Controls:
                as said on another subject wait for the next version which offer much more possibilities regarding mapping and also correct bugs (I suppose this is the one used in Retropie)
                but yeah I can confirm the bug on direction for sony analog sticks
                roman126 1 Reply Last reply Reply Quote 0
                • roman126
                  roman126 @voljega last edited by
                  @voljega @substring thanks guys I’ll wait the update and use another controller in the meantime
                  100.8k
