    Unsolved Games won't work if storage is usb and hat is on
    GamePad/GPIO/USB encoder
    wont storage usb hat
    2434
    • MR Karmeck
      MR Karmeck last edited by
      If I use USB storage and at the same time have the RetroTINK-ULTIMATE on, games won't boot. But they will boot from the SD card. Though it might be some setting I use that is stored on the USB that causes the issue. Or not, games stems I never changed also do not work.
      • MR Karmeck
        It worked now after a soft restart, doing a hard restart now....
        Works. Please ignore... Wonder why it happens though.
        • MR Karmeck
          This happened again today. So not really solved. A restart fixed the issue. But why is this happening. I'm using the official psu.
          • Dragu
            Dragu Banned last edited by
            @MR-Karmeck
            On the homepage of your hat is clearly written : "I only support Lakka" There are so much good shaders in Recalbox that you would not miss some booster behind.
              Substring @MR Karmeck last edited by
              @mr-karmeck when it crashed, generate a support archive
              MR Karmeck 1 Reply Last reply Reply Quote 0
              • MR Karmeck
                MR Karmeck @Substring last edited by
                @substring how?
                  @mr-karmeck gp tp http://recalbox/help if you're on windows, or http://recalbox.local/help for Mac/Linux
                  • MR Karmeck
                    @substring
                    That link did not work but I found it anyway. Seems to happen at random so might take some time befor I report back.
