    rpi3 wifi problem
    rpi3 wifi
    4684
    • asan nased
      asan nased last edited by
      hello, i have a problem with wifi, it does not work.
      ifconfig wlan0
      wlan0 Link encap:Ethernet HWaddr B8:27:EB:4B:4E:24
      UP BROADCAST MULTICAST MTU:1500 Metric:1
      RX packets:130 errors:0 dropped:130 overruns:0 frame:0
      TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:61664 (60.2 KiB) TX bytes:0 (0.0 B)
      grep wlan /var/log/messages
      Jan 1 01:00:04 RECALBOX daemon.info connmand[233]: wlan0 {create} index 3 type 1 <ETHER>
      Jan 1 01:00:04 RECALBOX daemon.info connmand[233]: wlan0 {update} flags 4098 <DOWN>
      Jan 1 01:00:04 RECALBOX daemon.info connmand[233]: wlan0 {newlink} index 3 address B8:27:EB:4B:4E:24 mtu 1500
      Jan 1 01:00:04 RECALBOX daemon.info connmand[233]: wlan0 {newlink} index 3 operstate 2 <DOWN>
      Jan 1 01:00:04 RECALBOX daemon.info connmand[233]: Adding interface wlan0 [ wifi ]
      Jan 1 01:00:18 RECALBOX user.err kernel: [ 19.964400] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
      Jan 1 01:00:18 RECALBOX daemon.info connmand[233]: wlan0 {update} flags 36931 <UP,RUNNING>
      Jan 1 01:00:18 RECALBOX daemon.info connmand[233]: wlan0 {newlink} index 3 address B8:27:EB:4B:4E:24 mtu 1500
      Jan 1 01:00:18 RECALBOX daemon.info connmand[233]: wlan0 {newlink} index 3 operstate 0 <UNKNOWN>
      Jan 1 01:00:18 RECALBOX daemon.info connmand[233]: wlan0 {update} flags 36867 <UP>
      Jan 1 01:00:18 RECALBOX daemon.info connmand[233]: wlan0 {newlink} index 3 operstate 2 <DOWN>
      Jan 1 01:00:18 RECALBOX user.info kernel: [ 19.968763] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
      dmesg |grep wlan
      uname -a
      Linux RECALBOX 4.4.13-v7 #1 SMP Sat Dec 2 12:59:51 UTC 2017 armv7l GNU/Linux
      ifdown wlan0
      ifdown: interface wlan0 not configured
      ifup wlan0
      ifup: ignoring unknown interface wlan0
        OyyoDams Staff @asan nased last edited by
        @asan-nased Hi,
        You can't use ifup/ifdown, we use connman to manage wifi.
        Anyway please check that:
        • your SSID is not hidden
        • your wifi channel is < 11
        • asan nased
          thanks, SSID is not hidden, channel was 13, i changed it to 9 and restarted router and rpi, but it does not help, wifi does not connect
            @asan-nased ok can you temporary connect an ethernet cable to the rpi ? Then connect to its IP with a web browser, go the support section, launch the support script, and paste the link here.
            • asan nased
              Download URL: https://file.ac/GUQ1gzPxi_M/
                @asan-nased all seems to be ok.
                Any special character in your wifi password ? (no need to write it here)
                • asan nased
                  no, only numbers
                    @asan-nased I don't know... No mac filter on your box ?
                    • asan nased
                      There are no filters. I do not see any attempts to establish connection at the router log files. I tested wifi with 2016-05-27-raspbian-jessie.img and it works, than i rewrited recalbox.img at SD card and configured wifi again and i still have this problem.
                      • asan nased
                        I do not understand why RX packets at WLAN0 interface dropped
                        ifconfig wlan0|grep RX
                              RX packets:143 errors:0 dropped:143 overruns:0 frame:0
                              RX bytes:66349 (64.7 KiB)  TX bytes:0 (0.0 B)
                        • Cheddar
                          Cheddar last edited by Cheddar
                          @oyyodams said in rpi3 wifi problem:
                          I have failed to connect to a Wifi with the SSID "GVT-25F0" but then succeded when routing from my phone (SSID: Cheese). If I were to guess, the issue is the "-".
                          Dont know if that helps but I think special characters are a problem on the name aswell.
                          Maybe try renaming the network?
                          • asan nased
                            I installed a new test router with OpenWrt, created SSID ABCAAA with kea AAAAAAAA and the rpi is still not connect to wifi, RX packets still drop.
                            • asan nased
                              When i try to start wifi via recalbox-config.sh script i get this error
                              pwd
                              /recalbox/scripts
                              ./recalbox-config.sh wifi disable
                              Disabled wifi
                              ./recalbox-config.sh wifi enable ABCAAA AAAAAAAA
                              Enabled wifi
                              Error /net/connman/technology/wifi: No carrier
                                @asan-nased you can't be connected to ethernet and wifi at the same time. Unplug your ethernet cable first.
                                asan nased 1 Reply Last reply Reply Quote 1
                                • asan nased
                                  asan nased @OyyoDams last edited by
                                  Thanks, all is working now, i think the problem was in 11 channel on the router and then connected ethernet
                                  100.9k
