    Recalbox Rca problem
    recalbox rca
    • 8bit_astronaut
      8bit_astronaut last edited by
      Hello everyone! i have a problem with recalbox.
      I made the configurations to get image on recalbox via the 3.5mm, and it works mostly fine, the problem is.... when i access a game, everything turns black, and i cant get image, but audio works.
      What could i've been doing wrong?
      I edited the config.txt in boot and changed sdtv=0
        check the dedicated wiki, seems you forgot the recalbox.conf edition
        https://github.com/recalbox/recalbox-os/wiki/Connect-your-recalbox-to-a-CRT-with-composite-(EN)
        8bit_astronaut 1 Reply Last reply Reply Quote 1
        • 8bit_astronaut
          8bit_astronaut @rockaddicted last edited by 8bit_astronaut
          @rockaddicted thanks! it helped a lot! now i get full image, my only problem, i cant adjust the image with the overscan option in config.txt, did i need to change something in the recalbox.conf?
            rockaddicted @8bit_astronaut last edited by
            @8bit_astronaut have you enabled the overscan with disable_overscan=0 as explained in the wiki ? https://github.com/recalbox/recalbox-os/wiki/Overscan-settings-(EN)
