    All core defaults
    core defaults
    3318
    • WSP77
      WSP77 last edited by
      Please, I have some mistakes on saving cores modifications and now I want to restore all of them to default. How can I do this? Thx.
        HELLO
        Go to emulationstation menu > game options.
        or edit recalbox.conf
        ## Default cores for RPi3
        snes.core=snes9x_next
        gba.core=mgba
        mame.core=mame078
        nes.core=fceunext
        delete others lines.
        https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN)
        • WSP77
          Thank you for your answer! But I'd prefer to make a backup of my roms and bios folder and make a clean reinstall of recalbox, by pressing "shift" at startup.
          BTW, why the system goes back to 4.0.0 after reinstal? I still needs to upgrade to 4.1 now.
            OyyoDams Staff @WSP77 last edited by
            @wsp77 because you have an old noobs installation.
            WSP77 1 Reply Last reply Reply Quote 1
            • WSP77
              WSP77 @OyyoDams last edited by
              @oyyodams said in All core defaults:
              I'm so noob that I don't know what is noobs instalation... ^^ Can I upgrade to 4.1 without any problem? I've tried to force update after reinstall, but it does not work. I'll try again later.
                @wsp77 you've installed Recalbox via Noobs - https://www.raspberrypi.org/downloads/noobs/
                Why not, but your Noobs version might be outdated.
                You can't upgrade from 4.0. My advice is to install directy from our website. Follow instructions from here: https://archive.recalbox.com/
                • WSP77
                  @OyyoDams It works 100%, now I have a clean instalation of 4.1, even a problem with black borders on my tv is now solved. Many thanks!
