    Custom resolutions
    custom resolutions
    • nickdj
      nickdj last edited by
      Good morning, I thought I would try recalbox on my monitor using a HDMI to DVI cable. It works fine when using OSMC but Recalbox does something different when booting up. I get the RPI 2 rainbow box fine, I get the recovery screen, but as soon as it boots into recalbox the resolution changes and my monitor can't handle it. Is there anywhere you can change the resolution? Is recalbox supposed to auto configure to the display? Is there a 'desktop mode' like you have in XBMC/Kodi? Kindest regards, Nick
      RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
      • hstampfl
        hstampfl last edited by
        Have you used the 3.2.5 beta or 3.2.4 version?
        I started my retro passion in 1985 with my C64.....Today I have a small (retro) console collection including NES, SNES, N64, GC, Wii, WiiU, GB, GBC, GBA, NDS, DSi, 3DS, 3DS XL, 2DS, NEW 3DS, SMS, SMD, SG, SD, XBOX, XBOX360, XBOX ONE, PSone, PS2, PS3, PS4, PSP, PS VITA, VECTREX, C64, AMIGA 600, MIST Board, Turbo Chamäleon
        • digitaLumberjack
          Hi, Remove hdmi_drive=2 line in config.txt 😉
          • digitaLumberjack
            I added it in the manual https://github.com/digitalLumberjack/recalbox-os/wiki/Manual-(EN)#b---other Maybe i should create a dedicated page for troubelshooting.
            • nickdj
              Thank for your help. I tried messing about with the config.txt file but not sure I tried that. Was using 3.2.3 at the time. Upgraded to 3.2.4 this morning so will give it another go but will definitely be trying out the beta later today. Cheers
