    Solved N64 Black Screen
    Emulator Arcade/PC/Console
    2827
    • kraethus
      kraethus last edited by
      I'm pretty new to raspberry pi/recalbox, so I'm probably doing something wrong, but I can't get N64 games to play. I had no issue with other NES, SNES, or Sega Genesis, but when I try to start an N64 game, it briefly brings me to a black screen and then backs out to the games list. I tried looking at other peoples posts and tried to troubleshoot based off those recommendations but nothing seems to work. So far I've tried following the instructions at https://github.com/recalbox/recalbox-os/wiki/N64-%3A-return-to-ES-(EN). I ran the commands listed there and then ended up changing the recalbox.conf file by switching the n64 emulator setting from the default DMT 4 HDMI to n64.videomode=CEA 1 HDMI. Other suggestions mentioned making sure the controller settings had an L and R configured. It's basically the same as an original N64 Controller, except it connects with USB so I don't think that'd be the issue. Just in case, I went into the controller config and made sure. Still no luck.
      I'm not sure what all information is useful in troubleshooting this, so here's what I have:
      Pi Version:
      Raspberry Pi 3 (RPi3) Model B Quad-Core 1.2 GHz 1 GB RAM
      Controller:
      N64 USB Controller
      Output from the commands I ran on the Github link above:
      tvservice -m DMT
      Group DMT has 1 modes:
      mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
      tvservice -m CEA
      Group CEA has 8 modes:
      mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
      mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
      mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
      (prefer) mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
      mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
      mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
      mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
      mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
        paradadf Staff @kraethus last edited by
        @kraethus it is probably related to your controller, but habe you tried this?
        https://forum.recalbox.com/topic/12223/n64-not-loading-games/2
        kraethus 2 Replies Last reply Reply Quote 0
        • kraethus
          kraethus @paradadf last edited by
          @paradadf Yeah, I made sure all of the roms are unzipped.
          • kraethus
            @paradadf I have no idea how, but I just kept trying to launch the games hoping for the best and after about the 20th time now it works all of the sudden.
              @kraethus inexplicable things that make our life harder 😉
              • 4biddenfruit
                4biddenfruit last edited by
                I'm facing exactly the same problem, do you have any clue what made it work for you? I also changed the aspect ratio in the config, but didnt not change anything "out of the box" beside that - only in the recalbox menu.
                Would love to hear your thoughts!
                Cheers,
                Yannic
                101.4k
