    N64 Not Loading Games
    Emulator Arcade/PC/Console
    loading
    • userreddit
      userreddit last edited by
      I am running a Pi3. I loaded some Super Nintendo ROMs on it with no issue. However, I tried to put some N64 ROMs on it to no avail. I tried twice actually. Both times, they seemed to upload, but when I rebooted the pi3 none of the ROMs showed up. I checked on the Manager as well and they do not seem to be there either, even though I saw them upload using the manager with my own two eyes.
        paradadf Staff @userreddit last edited by
        @userreddit n64 doesn’t support compressed rom files, so just unzipped them.
        userreddit 1 Reply Last reply Reply Quote 0
        • userreddit
          userreddit @paradadf last edited by
          @paradadf Thank you! Does that mean that the zipped files are somewhere on the microsd card, taking up space, even though they don't show up?
            @userreddit probably. Connect over WinSCP or using the Network Share directly from Windows Explorer and look directly into the folder.
