    Help, network doesn't work anymore
    n64 manette ps3
    • mc9625
      mc9625 last edited by
      I've been using recalbox for a while without any problem. But at certain point (I guess after a "brutal" power off, removing the power cord) the network has stopped to work. I have both a wi-fi USB Dongle and the ethernet cable. They worked both at the beginning. Now there's no way to let Recalbox see the network. I've tried to plug and plug the cable, re-setup the wi-fi dongle but with  no lucky. I guess if there's anything I can do instead of reinstall recalbox, since I've got tons of roms and I would prefer not to scrab again for all of them. Any suggestion?
      • joinski
        joinski last edited by
        I had this problem too and the only way to get rid of it was a full reinstall 😞 The user nickdj also had this, see: http://blog.recalbox.com/forums/topic/strange-network-bug-that-requires-a-recovery/ He already opened an issue for that, see here: https://github.com/digitalLumberjack/recalbox-os/issues/298 unfortunately the issue is still open and there was no respond yet 😞
          hi did you try to do a fsck with a pc under linux ?
