    Solved Can't connect second nes30pro controller via Bluetooth
    GamePad/GPIO/USB encoder
    nes30 bluetooth 8bitdo
    2969
    • neo-1986
      neo-1986 last edited by
      I have a ps4 controller connected via USB to do the setup. I successfully pair one nes30pro controller from 8bitdo. But when I want to do the same with the second one, it shows an error. Any help ? 😞
        OyyoDams Staff @neo-1986 last edited by
        @neo-1986 hi, what error do you get?
        neo-1986 1 Reply Last reply Reply Quote 0
        • neo-1986
          neo-1986 @OyyoDams last edited by
          @oyyodams "Verbindung fehlgeschlagen" so it means "connection failed". I can connect both nes30pro controllers, but only one at the same time. connecting the second one (no matter which one) doesn`t work... 😞
            @neo-1986 that's weird. I have 2 nes30pro controllers and both are paired without any issue.
            Let's try the the following:
            1. Make sure you have the latest firmware from 8bitdo installed on your controllers
            2. Forget all controllers assocation from Emulation Station
            3. Reset your controllers (see this page)
            4. Associate them again
            Does it work ?
            • neo-1986
              Did exactly 1. to 4. but still get the error message with the second controller "Verbindung mit Controller fehlgeschlagen"... = "Connection to Controller failed".
                @neo-1986 Ok so let's try a manual pairing.
                Please connect to Recalbox with a terminal
                Then follow this page
                If a pin code is asked, enter 0000
                • neo-1986
                  neo-1986 last edited by neo-1986
                  Thank you but I managed to connect them finally. I reseted the controllers over and over again. I was really angry and then... They connected 😮
                    @neo-1986 cool now have fun 🙂 Thanks for your feed back!
